jFET Power Buffer
If 20pF the only criteria than you can parallel 10x BF862 and get the same, with the benefit of ultra low noise.
But these will give me 20pF without having to parallel 10 devices (ultimately 20 devices seeing as this is a push-pull topology).
As for ultra low noise, I'm not going to be using them as common source amplifiers, but rather as source followers, fed by ultra low noise 1:10 microphone transformers.
If you are in for the kick-factor of using mysterous Russian military technology, that is another matter.
Hasn't anything to do with mysterious Russian military technology. Far as I can determine, these are basically Crystalonics CP650's in stud mount cases. And it's the latter that makes them more attractive to me than the CP650's (well, that and the fact that the CP650's go for $17.50 a pop).
I am sure it will also sound wonderful.
That remains to be seen. That's why I want to get some to try for myself.
Anything JFET sounds wonderful.
Yeah, they do have the fact that they're JFETs going for them. 😀
se
Patrick,
the cascode does not reduce capacitances. A rather high value of Rdson is another condition of linear behavior, 5 Ohms is fine for devices with this power handling capacity. And yes, a fairly low but flat transconductance.
Patrick,
About input capacitances, as I see it, in common source stage, it is roughthly a sum of Ciss + Crss x voltage gain.
Since the cascoded device does not experience voltage swing, it will have input capacitance without multiplication of Crss, i.e. simply Ciss+Crss.
My subjective view, the less input capacitance - the more tiniest sound detailes are resolved, the more close we to a tube stage.
Do we have a language problem ?
The KP903 has a transconductance at Idss (400mA) of 0.1A/V, or 0.1S.
The LU1014D has a transconductance at 1A bias of 4S, or 4A/V.
I assume 0.1S is lower than 4S and not Vice Versa ?
Kindly show me a JFET, even MOSFETs that has a Yfs of 4S at 1A.
And please also show me another Id vs Vgs curve that is anywhere near as flat at 1A.
Patrick
I have some personal building and listening experience, of several Zen9-like amps. I played with 40pcs of LD1014DA and 10pcs of LD1010DA (the last has 10S transconductance at 2A and Ciss close to 1600pF).
I reported stereo power amps, also two monoblock versions, the last was with near 5A idle current, with many high-quality parts, with various degrees of modulation of Aleph CS.
Now I am neutral to LU1014 parts, since in spite of several years efforts I have not managed to get equal with SE 300B amp, in vocal reproduction.
Now I look only at HF parts, MOSFETs and jFETs, with minimum possible Ciss.
And now I am proud about three last designs, all my friends say that they are superior now to both SE 300B and another push-pull tube amps.
It´s unwise not to use a cascode.
with some devices that maybe true, but I feel it is a compromise. The zen-9 article states that the cascode is more or less a slave device that adds nothing of it'self to the sound. I have no experience to refute that, but I can't help feeling that it's another device in the signal path, just happens to be in common base amplifier configuration. I'd rather do without a cascode if I can.
Right, more correctly, Ciss = Crss + Cgs. Actually, the gate capacitances are composed of two parts: linear fixed overlap capacitances that are independent of applied voltage and nonlinear charge storage capacitances that are associated with power handling so they cannot be made too small.
The large and useless Idmax of LU1014 (50A) brings about a lot of capacitance and a thousand times lower Rdson than that of KP903A.
Yes, therefore I do not think that the LU suites preamp or headphone amp schematics, the Zen9 is the most perfect place of its implementation, and Nelsonn Pass has indicated this ideal place.
Unfortunately, even in the best application, the resulting sound is very good, but far away from champions.
Without further explanation, it has been claimed that the statement that class A amplifiers biased with a constant current source draw constant current from the power supply is wrong, even more mysteriously, with the exception of the design of this thread.
The description of the "concept" with its "special features" is to be found below - sad to say, it`s all mumbo-jumbo to me.
