Jfet BOZ
for Zen Mod
Here is what I have. All ASCII I'm afraid....
No problem with ascii, just use the "PHP" button and :yes:
PHP:
l Audiophile MC Pre-Pre
Folks, with just few resistors, one JFET, one output cap you can build a
step-up device.
   12 Volts regulated or accumulator buffered supply
                    2k2
                     |---------0.47uF-----out------------>
                   (drain)             |
---in---------(gate)JFET              100k
         |        (source)             |
        100R         |                 |
         |          47R                |
-ground--------------------------------------------------
The basic topology is that of the second step-up amplifier by "Maison de
L Audiophile" of Paris/France.
The first 100R is the cartridge load, which must be adapted for the
cartridge you use. Using a paralleled 1nF cap also makes the circuit immune
against RF noise. The 47R resistor in the source is not necessary, if the
JFET has an IDSS(on) of 2mAmps or less.
As the signals are very sensitive, the voltage must be very clean, a 100 000
uF electrolytic cap for blocking power supply noise, computer grade
favourably, is advisable. Suitable JFETS are 2SK170, 2SK240 (double JFET),
2SK97 (double JFET), sorry only these japanese types are suitable, the
European BC264 and BF254 and so on do not work here (I tried !).
All resistors must be big metall resistors, e.g. Beyschlag 1Watt, or
tantalum resistors. No carbon resistors allowed here, tubes addicts.
The output cap is preferably polystyrene or polypropylene or paper-in-oil,
as you like it, as they are different in sonic balance.
Pacific RIAA Pre - 24V Version
              o-----------------------------------o------------+24V
             R2                                  R6
              |                               D---o---C7---o
          D---o---C1--R3--o--------o------o---G           OUT
  o---o---G               |        |      |   S---o        o
IN   |   S---o          R4        |      R5      |        |
  o   |       |           |        |      |       |        |
  |   |       |        o--o--o  o--o--o   |       |        |
  |   R1      |        |  |  |  |     |   |       |        |
  |   |       |        C2 C3 C4 C5    C6  |       |        |
  o---o-------o--------o--o--o--o-----o---o-------o--------o--- 0V
R1 = 100k C1 = 0.47 micro
R2 = 2.4k C2 = 15 nano (ideal C2 + C+ +C4 = 99.3 nF)
R3 =  27k C3 = 15 nano well my copy says 100nF
R4 =   3k C4 = 68 nano
R5 = 100k C5 = 22 nano here its 30nF total
R6 = 2.4k C6 = 6.8 nano
C7 = 2.2 micro
We build the Pre using both the Fet Pre Pre and the Pacific. PSU is 3 X PP3
NIMH Recharables. The Pre Pre get's it's PSU via a dropper resistor and a
2,200uF Decoupling Cap (Black Gate or similar) so that 12V are supplied to
the Pre-Pre.
Later Thorsten
great thread guys, me ordered the missing parts for this thingy today...
cheers, LC
mpmarino said:
Batteries might 'be cheating' but could you imagine this pre on batteries hooked up to a 12+12 marine battery mini A - into a set of Altec 19's.
:angel:
Yep I can🙂 Mark you know, whatever I can imagine. I can do😀 Loads of ppl told me that I was c****, he-he. My philosiphy goes like this: If you can/will build it, go ahead. If not, shut the f*** up!
There are a few of the last category here on the board who think they contribute with something usefull!!😱 😱
Sorry if I stepped on anyones toes😀 Harsh guy, signing out😉
Steen 😎
As steen is doing the hard job, I can concentrate on serious listening.
For unhappy few who did not buid the pre : a cat is a very good test instrument. Playing "interview with a cat"/Marcel Brodhaerth, for exemple. Watch the reaction of the cat.
If I am too much OT, tell me , I will be quiet, very quiet, vanishing...
manu
Nope I am not doing any hard job, yet!! I just put together the circuit and relied on Mr. Pass's judgement and adjusted the input pots to half resistance😀 He-he that was the easy solution, but what do you expect from the Lucky L..... guy?? Fast and Furious:devilr: I will give it a more serious walkover later!!
Steen🙂
Steen🙂
Do you have both the input pot from papa drawing and another one at the input for selecting the volume?
Not that there is anything wrong about it, I'm just curious.
steenoe said:
I have no idea why you find this surprising???? Please elaborate on that. I was surprised by the sound of a simple circuit like that, but I dont think that is what you are aiming at?? What is your (ahem) aim??
Steen:att'n:
Well, i tend to take your opinion about sound and in particular Pass circuits seriously. From your unbridled enthusiasm i got the impression this is the best you've ever heard. Should i not be surprised?
Zen Mod
Thanks for posting all the old info.
manu
No problem, just don't get too serious 😀
Hey...I was offline for a few hours and WOw I see that Steen is already listening to his preamp! Congratulations! Steen, are you using the exact Nelson's schematic? Did you change any resistor value?
Judging from Steen's experience, this is really going to be a "diamond" preamp!
We can only :worship: to Nelson!
Thank you guys for the support...now I have to hurry....gotta build that pre!!
Vix
Sorry Manu. Your experience counts as well. I was mostly interested to know how will Jfet Boz sound with F4. Steen was the first one to try that.
(Ok, Nelson was first....)
By the way, Nelson, are you listening to this combination right now? (even if you have something better, please don't tell us, at least not now!:clown: )
Vix
Here's my little mess 🙂
I get about 5.1v across the jfets. I went thru about 7 of them to get them close. Are they normally that badly matched??
Anyway - can't try it tonight it's a bit too late:bawling:
Zen Mod
I wont go as far as to say its the best I ever heard.
Was I too enthusiastic? I dont know! The easy way for you to find out, is to simply build one for yourself😉 Takes almost 2 hours to get one in the air😎 Its not my fault that Mr. Pass sends out all those very well sounding circuits😀
Vix, I used the values as in the schematic except for the source resistor. Funny enough I was out of 10r's too, so I had to use two 27r's in parallel.
I will try and finetune the circuit this weekend.
Steen🙂
Nice work Marino. Not as messy as mine though😀
At some point I had a pair of J-fets with 4,3V and 5,6V, VDS. Quite a difference.
Steen🙂
