J-Mo Mk II headphone amplifier
Here you have the layout... same schematic but different fet and mosfet.
Salas BiB... double mono... before that I have kentoken Kmultiplier... I experimented a lot with several psu and the design responds to the slightest change.... now it is incredibly smooth with bite and attack. No harshness, just power.
My original prototype boards were customized to match high impedance headphones. I made the mistake of setting the circuit gain too high: I ran out of open loop gain, and it was a mess.
I scrapped the custom boards (which were, sadly, rather nice with Nichicon MUSE, 2SK214 FETs) and subbed the stock circuit on the shipping boards. The gain is about 3x (10 dB) so the distortion of the input section is kept well in check. Unfortunately the low gain rules out my HD600s, but I'll keep the amp for low impedance use as it sounds pretty nice.
Test notes:
With a gain of only 10 dB, this is a bad match for my HD600 references, and I don't have a decent set of low impedance headphones in the house.
Fortunately the JFet input stage means the circuit is tolerant to being used with the volume control cranked up to 2-3 o'clock, so I gave it a try.
Okay, so its surprisingly good! I mean, it doesn't sound like my previous experience with MOSFET followers, which were warm and muddy: this is clean and precise, with no hint of high 2nd harmonic, and it convenes that low-level, micro-perfection of timbre that I associate with single-ended output stages.
If it loses anything to the other headphone amps I have here (see photo), its because the parts quality just isn't quite up to the same standard, the others being fully cost-no-object, high-end equipment. So maybe its a little bit ragged in comparison, but very respectable nonetheless. (And a lot of that might very well be the missmatch between headphone and amp.)
I know, and this is such a rugged little circuit! Runs off just about anything, and essentially worry-free: set the bias once with the trimmer and you're done. With output coupling caps JFET inputs, and protection diodes, it can take more than its fair share of abuse and still sound great.
