Only took the "bottom" of one box, will build to piece-by-piece.
Did you take 2 existing boxes apart to make 1 big 1?
Sometimes it helps to look at my own pics......I laminated some boards together, will cut on band saw.
Idea stolen from a recent thread 😛
Your straight board solution would work just fine.
Hi ODougbo,
When you "laminate boards together" do you use bisquits, or any kind of reinforcement/alignment?
nope lots of glue....biscuits/dowels are for "ends", which I'm going to do for this build.
A little dowel jig is good to have around!!! I'll take some pics.
Pic
The divider may be too big, only 2-3/4" at the inside corner.
The dowel jig is old but works as good as ever, you just buy the dowel inserts.
😵 using table saw as a stump grinder now are we?
Do we still have all our fingers?
U R CRAZY!
What is this I see about the Type X 10", what model #???
U R CRAZY!
yeah stump grinding, I wouldn't recommend that unless you are really comfortable with a table saw; it's a common practice; also can be done on an anlge. I had a 4x4 steel angle set 90 degress, it wasn't hard, made a lot of dust. DO NOT MAKE DEEP PASESS 😱
The Alpine?? humm don't know the model #...I could have had 30 of the 6 1/2 woofers vs. one Alpine, which btw...the 6-1/2" are working well.
The issue with the Alpine, I had to turn it up too loud to get bass...It's an incredible woofer, but didn't fit the HT, not in the BR box anyway.
It will shoot poofs of air across the room....talk about realism in action scenes.
The Plot Thickens....
I found that some of the terminals were installed backwards on some of the woofers........
That must have been the problem when it didn't sound right....day 1.
Double/Triple Check with AA battery!
6-1/2" Subwoofer Speaker 299-114
Oh boy, not even close, just a bonking noise......
- Subwoofers
- Isobaric - less then $20
