Iron Pre Essentials Kits For The DIYA Store - Register Your Interest
May I lower R3/4 combo to approx 3ohm for additional CCS to power NP 6-24 crossover from the pos rail.? It requires 120mA and if I keep spare CCS to the 80mA I create no more heat in M1. Is the rest of the circuit happy with that?!
you may, allowing proper heatsinking of BD and IRF devices of Good Gemini (code name for shunt reg of Iron Pre), and appropriate size of xformer; for approx 220mA of programmed current, steady juice (for just one secondary/rail) is 0A22*18V=3.96W
for that, no less than 30VA Donut
but, fact is that seating both Iron Pre pcb(s) and Papa's Xover in one enclosure isn't so easy and both of them are really deserving own separate case for best wiring arrangement, you're in situation of needing long wires from shunt regs to Xover pcbs, pretty much no-no in my book, negating benefits you have of (any) regulated supply
also, no small Donut is happy with unequal loading of secondaries; you can do that with xformers dedicated to auxiliary circuits, but not advisable for xformers where center tap is used as direct connected audio GND
in short - I wouldn't do that
Hi Zen Mod,
What I asked about transformer was Auto-transformer. So I am planning to build one.
There is metglas core and finemet core version.
Do you find different sound quality?
Finemet is giving even more low level information, through entire spectrum
Very!! far from Metglas being bad, but Finemet is better
Not much, but it's in our nature to always shoot for overkill
anyhow, when you have completed AVC with switching, connection is as per sketch in post #2113
OK!
One more thing:
I have some AWG30 wire wrap cable on the way for the input wiring (silvered 🙂 ).
I was thinking about the technical reason for using very thin wires for input.
Is it primarily to have theoretical same impedans for all frequencies (e.g. 20 - 100 Khz):
https://www.powerstream.com/Wire_Size.htm
I was also thinking about when those thin wires are twisted then the coupling is very close and then maybe less chance for e.g. magnetic noise to couple to the "cable"?
there are many technical explanations why thin conductor should/is sounding better for small signal
though, you can hear/read them all, then you're in same situation as plain Believer - if you need to ask, then certainly you don't have knowledge and/or necessary apparatus to actually test and confirm/deny said claims
so, I'm stuck on tasting and not testing - thin signal wires are best to my ears, in my system setup logic
and I believe that Buddha is everywhere
:clown:
Ok,
I have an unfinished experiment using twisted PTFE silvered wire cables as RCA cable. I never got them terminated.
It was to make a very cheap DIY RCA cable that has low capacitance and immune to magnetic fields. For RCA I would connect black and blue to Gnd and red to hot (could be used for XLR also I assume).
Now with AWG30 I could try the same and it should work very well? ......better then XXX $ cables? 🙂
Apart from a maybe little problem with physical strength.......it could be fun to try.
Maybe a little bit off topic......but as you can see.......IP-schematic is included.......
