Anyone is better then the dreaded UPS.last week with DHL.
You going for the illusive 20db gain? You have better lighting in the Caboose. I expect pics so I don't release any more smoke from my pair, then I normaly do, up front on the engine.
I got some Edcors
No, I'm gonna get them built normally. I can use a "normal" balanced preamp around the house, I don't have any right now. It'd be nice to try them with the A2s and A5s.
The 20db gain is still in the planning stages.
I may then be on my own. Depends on all the other stillborn projects I sleep with.The 20db gain is still in the planning stages.
You know, take a balanced input, output a balanced output for a nice 1:6 gain? How would such a thing be possible?
I believe I gave you recipe exactly for that, or close to that, when I was pointing you to Boo and Pooh
Edcor 600:15K (you have two versions, bigger one (physically and by W) capable of higher swing) is having CT both on primary and secondary, so made for balanced/differential
600:15K nominally means 1:5 voltage-wise
btw. transformer is inherently balanced Beastie, per se
when you have CT present, it just gives us less headache to incorporate it in rest of circuit
"tonyEE said:
I have some of them 1:6 gizmos laying around..."
I ordered (I thought correctly by Zen) 15K Ω to 600 Ω (5:1 ratio)
Is the ratio dependant on prefix being less or more? 😕
I ordered ratio 5 to 1clarify
tonyEE has 1 to 6
Is that(?) I have output gain of 5 times and tonyEE has slightly above 1x? Or, have I got this wrong?
worth checking is it the same xformer 600:15K as 15K:600
that's question you need to ask Edcor, did you ordered what you actually need
tony is having own stash of various xformers
Shopping cart
Zen, I assumed this was/is the correct xfomer. Cut/Paste from order.
The ratio seems to match your requirements. 15K to 600 OHM. 600 to 15K is (my math, about 1.5 gain or less)
The analog method to determine what I'm getting from Edcor is to install and measure. If incorrect it will become part of my stash of critters.
Product image | Description | Quantity | Price |
![]() 2 | PC Series - 1/4W balanced or unbalanced line matching transformers.15K Ω to 600 Ω (5:1 ratio) | 2 | $36.46 |
I can't say, without knowing their winding chart, is 600:15K same as 15K:600
I'm sure that you can wire them backwards and it'll work
but if they're made with some tricks, then having them backwards isn't optimum
best to ask Edcor - can I use it backwards, without any penalties?
Now I don't know what is required. 1.5x or 5x for the Iron Pre. I have two possibilities. One is wrong. I made one choice TBD correct then. If wrong, I will re-order and not run backwards. I wire large 3 phase trannys backwards to run 440V motors on 220V. The scaling is totally different I would imagine.
tonyEE has 1 to 6
I got those to amplify an SE signal... I will look into ZM's advice.
The Iron I bought are both SE. Waiting on store to fulfill my Bal request.amplify an SE signal
I don't know what you want
if you want to use said xformer to achieve with it voltage gain of 1:5 ( it can be wired in whatever combination of Bal and SE), you needed to order 600R:15K
ask Edcor can you use ordered 15K:600R wired backward
just a reminder, whatever xformer brand/type is used in Iron Pre (be it SE or BAL), all of them are 600:600
clearly written on schematics and I believe so - also in BOMs, IAIMH posted
Enough gain to drive F4 dual mono. Have stock and higher gain BA-3 pre to test. Then Iron Pre after long wait is priority.I don't know what you want
To play well with MonoBloc MOFO's. Later when Dual Mono F5Tc finished. Sony VFET series 1, M2, etc.
Then I have it wrong and will put in bin and order 600R:15K. 😳you needed to order 600R:15K
Danke, Zen Master!
Hi guys, what if I use 50k + 50k log volume pot? I should change it in a second time...
Gaetano.
Gaetano.
- Iron Pre Essentials Kits For The DIYA Store - Register Your Interest
