IRFP240/9240 Amplifier (simulated on TINA)
The new "un-case" 2U amp enclosure works well with VHEX+ amp. Abletec SMPS and CRC filters are working well. Super wide soundstage, very clean, clear with superb dynamics an headroom.
Cool idea with plexiglass top cover. It's interesting how the LEDs are much more than just a visual indicator in this amp - they provide the low noise CCS voltage references.
Yes, they are thermally stable and low noise enough - red LEDs are especially good, giving around 1.8V reference. Green ones are also good (2.1V). Blue ones (3.4V) are a little bit more noisy - in some cases (output stage follower) it does not really matter, but in more critical locations (e.g. input stage CCS) it's better to use the red ones or a double-transistor arrangement with feedback, as I did in VHex.
I have just modelled PSRR - simulation of VHex+ shows 64db.
The newer version - VHex+BT (coming soon, prototyping now) will provide 70db.
Hi Valery,just for the story,this time it's impossible to find red led 1.8v reference,all stay around 2+ volt.
I've been using Kingbrite WP710A10LID, which Mouse calls "standard" leds. Kingbrite lists them as high efficiency too. Is there any issue using high efficiency as long as the voltage drop is correct? Is there a difference in thermal characteristics?
http://www.mouser.com/ds/2/216/WP710A10LID-231305.pdf
Pdf clearly say,this is a high efficiency device(2mA)
Are these suitable for Pitchfork pre-amplifier?
