Introducing the Buffalo III-SE-Pro 9028/9038
Yeah - you should not get any pops etc as long as your source is not sending any. 🙂
As to your DSD512 playback funkiness - I would look at the source since I have had no issues playing DSD512 from BBB in pure sync mode - though Amanero is more problematic (I suspect that's down to it's own slave mode firmware needing some work)
Thanks for the report!
Cheers!
Russ
-snip- Sounds very good! The only issue I have is that with DSD512 I get a high pitched constant noise superimposed on the music, and only in the right channel. Changing back to DSD256 the noise completely disappears.
I think this high pitched noise, if it is heard like a chirpy sound, should be the issue of Amanero firmware. Anyway congratulations for your modified B3SEpro firmware well working.
Awesome. Thanks Russ! I didn't see this file earlier. Will start by (hopefully) implementing your stock settings. Then, I can hardly wait to experiment and will add filter options, etc. as time and experimentation allow.
My Python interface uses an asyncore server, adapted from NetIO. I just noticed the TPA logo at the bottom of this page - though the picture rotates... 🙂 [I use NetIO to easily create I2C control pages on all my iOS devices.]
Cheers!
Frank
I seem to have hit a snag and could use any suggestions. When using the new Pro boards with the firmware chip removed, is there any reason that the I2C busses would not initialize correctly for 3-wire (including ground) transfer? My I2C multiplexer doesn’t seem to find the DACs. The older 9018s worked fine in the exact same setup - I simply swapped them out.
TIA,
Frank
Apologies, Brian & Dimdim! My hobbyist's brain has been in 'medicine mode' for too long... :wchair:
Backing up: Will I need on-board firmware simply to change the power-on state and thereby initialize/activate the I2C bus? [There's a "learning opportunity"! :Present:] Or is there an easier way?
F.
Hopefully a simple question. I have built a IIIse based dac using a Raspberry Pi using i2c and a Kali Reclocker as a dedicated input I would also like to add some spdif inputs to the IIIse (CD Transport, another Pi for video streaming and an ADC — all via coaxial spdif ) and I am a little bit confused about what is needed to add three spdif inputs and switch between the i2c and the spdif inputs.
Can someone explain what is needed, I assume the 4:1 Muxer and how to switch between the i2c input and the Spdif Muxer
Also how is switching between the built in spdif and i2c input managed?
I am sorry if this is explained clearly somewhere I have looked but I cannot see it.
