"I love the smell of burning Teflon in the morning"
I see you met our intern of a few years ago. That lad was a pro at making high voltage power supplies arc and he managed to blow an amazing amount of multimeters 😀
But those connectors are the defacto ones on most high voltage powersupplies we have in the labs. Safe for a few amps of current and very high potentials, beyond what is reasonable for an amplifier. One piece of warning though, they can be disconnected quite easily by design and I would not trust them unsupervised with children around as curious fingers could disconnect them and get a shock. One in a million freak accident but still worth to keep in mind
I used Amphenol MILspec locking connectors from Mouser for the 1100v B+ (I can't find the exact reference) and 5kV rated silicon isolated wire.
For the 350v and bias supply I used some locking militay-style Chinese connector off eBay. Good enough quality.
A decent knock off of those can be found on Ali for about 1/5 of the name thing, but YMMV.
I know the left one from work, it is sometimes used for the remote control of welding equiptment (handheld TIG torch)
Wow... Each screw is a drilled hole in the panel... Did you use also that thing to make the screw thread in the panel?Photos:
And how did you make the connecting cable (i mean that containing 4 and 5 wires)?
If you have time, would you mind taking a pic of the enclosure rears? Thank you!
Hole punches are great, if you only have a cordless drill to work with.
Try to get the one with the roller bearing on top, these have far less friction and are easier when you need to do mild steel.
They take longer than a step drill, but a step drill needs more de-burring, and a step drill with a cordless power tool is not ideal..
Shunt idea.
I had some stupid idea to do a shunt regulator with some cheap run of the mill components. Nothing special in here:
The most expensive part is the TIP50 transistor at about 50 cents. If you want better performance the toshiba TTA006B may do the trick.
Those shunt blocks are just plain TL431 shunt regulators in shunt configuration. And they are dead quiet like this.. depending on the grade they produce about 10-25uV RMS noise.
So friends, last question about output transformer:
I read that max output power for a gm70 is 43W @1200V plate.
Now on my shortlist there are these with high impedance:
Fc-40-10s SE Iso (former Tango) 10k primary impedance, 40W, around €900 each;
Fc-30-10s iso 10k, for 30W, around €520 each
Vincent's lundhal ll1168, different input impedances (5k2, 9k), 30W (or 60w according to primaryZ) power, around €350 each,
Monolith sa-15, amorphous core, Z=6.1k, 30W, €730 each.
Will 10k not be too much?
Will 30W suffice?
Will 30W suffice?
There's also Product & Price - NP Acoustic , 10K, amorphous. I have only tried the Lundahl, I don't know about the others.
If you go with the source follower, you will probably get at least 30W of power (my amp with D3a+CCS does 25W before clipping).
Did anyone here go Hammond or Toroidy? they may be a little bit too low budget for many here but I'm curious
Mmmm....There's also Product & Price - NP Acoustic , 10K, amorphous. I have only tried the Lundahl, I don't know about the others.
Vietnam?
They are very good OPT for their cost. I used a 3K SE amorphous one in my 4P1L PSE amp many years ago with excellent results
Do you believe I already sent a quotation request?They are very good OPT for their cost. I used a 3K SE amorphous one in my 4P1L PSE amp many years ago with excellent results
Now let's hope they'll answer
- Tubes / Valves
- Interesting GM70 scheme... Some questions on the PSU, who helps me please?
