Infineon MA12070 Class D
Hi. I hope someone can help me out.
I bought the MA12070 board from Audiophonics (MA12070 board) and I'm gonna use it in BTL mode in order to drive 2 top speakers. My input is balanced out from a 3E DSP board.
There's only 1 ground input on the amp, does that mean that I have to wire the 2 ground connections from the DSP board together, and otherwise connect + and - to the respective inputs?
Finally completed my MA12070P (i2s version) amp. My first SMD design and build. Thanks to similar projects by matt_garman and Fabianmu in convincing me that QFN packages can indeed be soldered at home with a bit of practice.
I'm running it at 24v and works fine. All my SMD MLCC caps are rated 50v to take into account any degradation of capacitance due to voltage biasing.
The amp is quiet. I implemented the output filter with a 1.5uH inductor as recommended by Infineon. I took a chance with the lowest recommended inductance since I could get a decent 30A saturation current rating without a monster sized inductor. At least I know that the output currents are far from saturation and the filter is operating in the linear area of the inductor.
The board also has space for input film caps when I build the analog version later
So far liking the sound. Either its my imagination, but there is a 3D like sound, perhaps better imaging? I'll do some A/B testing at a later date. The efficiency of the amp is as advertised and the chip gets just warm while the inductors remain cold even when pushed hard. I won't bother with a heatsink for this one.
The only issue I face is in the software side. Some bugs with the volume control via I2C. Like theAnonymous, I'm not a software person and will probably take longer than most to iron it out.
@altus fidelitas - your amp looks brilliant, thanks for the pics!
Would you be open to sharing the schematics/layouts? I'm planning on building a multi-channel amp using the MA12070P and Linkplay A31 source, and would love to use your layout as a starting point if you're open to it?
Hi all, wondering if anyone can help diagnose a noisy Shenzhen Pillor MA12070P board (PL-AD-160, marked V1.4)?
Thanks to some great tips earlier in this thread (nice even the designer has dropped in) I finally got this board working, hooray! At first I thought problems were all software related - I am connecting to an Orange Pi One SBC running Armbian which lacks the drivers available on the Raspberry Pi and trying to port them got a bit tricky. But fixing the PCB population errors to remove caps on the I2S input pins, connect master clock etc I now have a working I2S connection and can manually control volume and power mode, etc over I2C without the complete Merus driver.
However the board produces a disappointingly loud high frequency hiss from my (desktop) speakers, audible on top of music at low volumes. It is much worse than the other class D amps I have. Again I first suspected software, the volume control adjustment on input or mistakes over format conversions, but the I2S looks good and hiss remains constant if I mute the channels over I2C or use I2C volume control. (Using the MUTE hardware pin or stopping the I2S stream turns off the speakers). I've tried a range of PSUs/voltages and noise varies slightly but is still the same volume even with batteries. I'm using 2.0 BTL which shouldn't need blocking output caps according to the datasheet. It is as if the gain is set too high, but I2C doesn't help with that - I can increase the gain with register 0x25 but that just makes hiss worse.
Has anyone succeeded to get a clean/clear output from this board variant, are more alterations needed?
Thanks in advance.
Hopefully I'm not confusing your board with another one, but I was under the impression that master clock should not be connected. See post #524.
FWIW: Got a Aiyima A8 with a single MA12070 and it outperforms my DIY amplifier. It has drawbacks like many opamps and ceramic caps but it still sounds better. Bummer. When you switch it on the first seconds the air core coils make some noise 🙂 Also no caps after the coils which is awkward. It has a complete useless "bass boost" function and a non standard appearance which I like. When an A8 is bought make sure to clean the PCB as it was relatively dirty with flux etc. For the price I paid it has an excellent price/quality ratio.
So back to the drawing board. it will be a MA12070 module based amplifier driven by transformers so a passive input section. Linear Power Supply too.
Reactions: Radian
Any chance of some pictures of the Aiyima A8 internals?
Hi Jean Paul,
I just bougt this amp.
Do you think the input is balanced?
I want to skip all opamps and feet the chip from AK4493 balanced via Transformer
Klaus
Just the amplifier (A8) without the tube preamp?
Yes it was so cheap that I had to try it out. Strong suspicion that the tube in the preamp is just a gimmick.
Hi Jean Paul,
Klaus
Yes the AM12070 itself of course is balanced input but I put it back together. Same idea to skip a few opamps.
The circuit of “bass boost” can be omitted just like the “active output”.
Thanks for the suggestion. But if I disconnect (M)CLK I get no sound, this was one of the original problems to start. I think post #388 is accurate. Also if you check Infineon's circuit diagram for their RPi Zero Hat it connects both MCLK and SCK to BCLK from the Pi.
I'm now wondering if the 5V AVDD/VDD from the TPS62175 buck converter on this board is the cause of the noisy output. It looks like the voltage divider used for feedback has three times the recommended resistance in the TI datasheet, which remarks that higher currents are better for noise immunity. Or maybe there is some bad modulation with the regulators used on the SBC.
Did you get ESP32 squeezelite working with this chip in the end, by the way? That was my original idea for driving this board!
Yes I did, but not using that board. When they released the 32 bit version of Squeezelite-ESP32, I installed it and it worked! Later, I realized that it only worked because the 32 bit version created a BCLK that the MA12070P accepted. Using the 16 bit version, a 44.1K sample rate gave me an invalid BCLK.
By forcing a sample rate of 88.2K or 96K the generated BCLK became acceptable.
They also added MCLK as an output, and that worked, but I got more noise using it so I went back to shorting BCLK and MCLK together and feeding BCLK only.
I haven't fired that amp up in a while, but I would be happy to do so and send you the NVS parameters that worked for me.
Mike
