IGBT amplifiers
Eva said:
That's not completely true. The "MOSFET driving BIPOLAR" tale is only a popular way of explaining IGBT behaviour to straight people. An IGBT is a device having a single die and an unique structure which combines the advantages of MOS "channel" effect and bipolar "charge storage" effect. The absence of second breakdown is a consequences of this combination.
The following document shows the internal layout of old and new generation IGBTs and compares them to MOSFET for high voltage switching applications:
http://www.irf.com/technical-info/whitepaper/apec03nptigbt.pdf
Fair enough, but the reference only discusses the devices as
switches, so it really doesn't address any issues in linear use.
I have not tried these, but I have experience with the Toshiba
complementary devices circa 1989. I found that the matching
issues were real and I didn't see performance improvements that
justified the effort or cost.
Several companies rushed products to market, only to backtrack
after a period of time. Reliability appears to have been an issue,
perhaps not the fault of the devices themselves, and of course
the point became moot when the complementary parts were
discontinued.
Upupa Epops said:
Yes, it's true, but I mean that we aren't talking about kW amps or switching applications....
😉 ....eg. like this one with 192 x 310W IGBTs for a output of +/-400V @ +/-30A
For lower power linear amplifiers we already have a wide choice of popular low cost high performance transistors. MOSFET devices excel when they are not required to block more than 200 volts, and audio bipolars have a nicely flat current gain as opposed to the square law of MOS devices. However, there is really little stuff for "KW" amplifiers.
With series connections on balanced circuits with 200V devices
we can approach +/- 400V peaks, which is:
mumble..mumble...
10 KW rms into 8
20 KW rms into 4
40 KW rms into 2
Of course your real mileage will be less than that.
mumble..mumble...
10 KW rms into 8
20 KW rms into 4
40 KW rms into 2
Can't plug that amp into a regular outlet. Standard 20 amp household receptacle only provides 2.4KVA @ 120 VAC. What kind of power supply do you use for an amp that big? A pole pig (distribution transformer)?
I have been built
an Elector IGBT amp
by Giesberts...
That one from the first page SCH
while ago (1998?)
that was two mono blocks in same chasis...
I must say that was amp to remeber
realy...
etremly fast sound
excelent dumping factor
and operation i class A to about 2.5W
with 400mA cuescient current
the amp shows no Sandy sound against MOSFET amps
sound sometimes could be compared with germanium amps...
IGBT devices was not coupled
but all other BC550C/BC560C was...
I remember that I get better values then at the specimen measured,
build by Elector
IGBT
Threshold made 2 series of amplifiers using IGBTs, the T series and Forte.
Personally, I think they are still some of the best sounding amps out there and that IGBTs are one of the best sounding output devices. I will be comparing my Threshold T400 to a X150 shortly. The T400 is ready for a recap-90000+ hours, so it may not be a fair comparison but speaks volumes as to their reliability in a power amp application.
Class A operation is not a problem with N channel only devices. I'm not sure there are currently any suitable devices in production as most of the newer parts have an integrated snubber diode for motor controller applications which again speaks to reliability.
I Believe My Ears... Forget Theory
Sorry to revive an old thread...
I own several old Forte Model 4's and I can say with no reservations that they continue to compete with today's best offerings. The ONLY caveat I would add is that they're a bit week in the lowest octaves. However, they're very clean and detailed from midbass through the highest octaves. They are finely detailed without a HINT of harshness. I'm told that the updates available from V.A.R. further enhance these little amps' performance, particularly in the bottom end.
Regarding bass weakness: I use larger amps for my subs and reserve the sweet Class A 50 WPC for the frequency range in which these babies excell.
I believe my ears rather than formulae or theory. I frankly don't care what output devices they use. My ears are the most important/trusted measuring devices I could ever own.
Just made this amp out of scraped parts lying here & there for a friend of mine........It uses 5 Pairs of APT100GF60LR IGBT to get 1.6KW in Class-AB. The topology is All N-channel with Grounded Output .......😉
