Ideal bridge rectifier GB
This group buy is closed and there is no other open for Saligny LC or Saligny HV.
Saligny LC and standard (51Vac) are in production and will be available trough distributors.
Saligny HV 200Vdc is planned for production in August.
I'll present in this thread some pictures and where you may purchase these.
Tibi
center tapped transformer and LT4320
I´m wondering if the LT4320 is able to handle with symmetric power rails. I designed the following schematic and build the circuit but as soon I connect the 0V (center tapp) rail from the Transformer to the circuit GND, I get high current flow through the center tapp.
I measured the circuit with the Oszilloskope an found the same as in the Datasheed. So the basic circuit is as expected.
Any suggestions and recommendations are welcome.
