Ideal bridge rectifier GB
Yes >250V. Advantages are low profile, no heatsink, less noise.
Even at high voltage you save lot of power dissipated as thermal heat, you have far less noise than any diode. Diodes have important switching noise at high voltage.
Your transfomer will deliver his top power and your amplifier will sound sensible better.
Regards,
Tibi
Saligny LC is ready.
Layout 10mmx10mm
Max 35Vac or 50Vdc
continuous 6A, max 8A
Please show your interest here and I'll let you know when these are available and from where.
Thanks & Regards,
Tibi
Hi tvicol
I am interested in four LC versions and two HC versions for now. I hope you will find a distributor soon because I am now buying parts for a multi rail power supply for my audio computer.
Also my pre- and power amplifier could do with your ideal rectifier.
Also I hope that with distributors the prices will not go up!!
