So only 200V version will be available? 450V version not available yet?
Max. dc voltage 280V
Yes >250V. Advantages are low profile, no heatsink, less noise.
Even at high voltage you save lot of power dissipated as thermal heat, you have far less noise than any diode. Diodes have important switching noise at high voltage.
Your transfomer will deliver his top power and your amplifier will sound sensible better.
Tibi
Tibi
Just to understand better: can i use it to rectify a 250Vac transformer secondary (that's not particularly high voltage for tubes psu)?
250V ac is quite high for Saligny HV.
For tubes you'll have to wait, or build yourself one based on the schematic I posted in this thread.
Tibi
Tibi
Sorry if it has been asked before but what about the low current version? Any specs on that and when will it go into production? 5A or 6A would be nice ( hahaha low current)
I could use at least 6 of them.
For now I would like to have two HC versions.
Saligny LC is ready.
Layout 10mmx10mm
Max 35Vac or 50Vdc
continuous 6A, max 8A
Good! Can we order the HC version yet or shall we wait for a distributor to be found?
You mean HV. I'll take orders when ready. And yes, we are looking for distributors for Saligny.
Tibi
Tibi
Tibi
Ok, but i was asking about the LV HC version, the one this thread was originally about
I'll not run another GB. You'll have to wait for a distributor to start sale our product.
Tibi
Please show your interest here and I'll let you know when these are available and from where.
Thanks & Regards,
Tibi
Thanks & Regards,
Tibi
Thanks & Regards,
Tibi
Hi tvicol
I am interested in four LC versions and two HC versions for now. I hope you will find a distributor soon because I am now buying parts for a multi rail power supply for my audio computer.
Also my pre- and power amplifier could do with your ideal rectifier.
Also I hope that with distributors the prices will not go up!!
- Group Buys
- Ideal bridge rectifier GB
