Ideal bridge rectifier GB
Next week I'll open second Ideal Bridge Group Buy.
I'll offer Saligny Standard, Saligny LC (low current), Salignt HV (high voltage) and Saligny HC (high current).
Saligny HC will able to starte to operate from as low as 1Vac with good performance at 4Vac up to 40Vac and over 100A continuous using top performance under miliohm mosfets.
Saligny HC is the single bridge that will operate full wave rectification with centre tap transformer.
Regards,
Tibi
tvicol - 4 Saligny HV @ 160Vac
nautibuoy - 1 Saligny HV
Jazid - 2 Saligny HV
ste - 1 Saligny HV
Luca72c - 3 Saligny HV 2 @ 80Vac with CT if possible; 1 @ 170Vac
Rinman77 - 4 Saligny HV
merlin el mago - 1 Saligny HV
nightsky -2 Saligny HV
s610adam - 4 Saligny HV
joimonf - 1 Saligny HV
tjencks - 2 Saligny HV
Total = 25
Saligny HV used with CT will operate half-wave, but at higher current.
I strongly recommend to use two separate secondary with two bridges.
Regards,
Tibi
Ok, so let's say 3 @ 170 Vac, as i don't know for sure what i'll use 2 of them for: i was hoping to use them for 72Vac CT. For double, 2 secondaries 36Vac CT then i'll use 4 normal Saligny
nautibuoy - 1 Saligny HV @ 120VAC
ste - 1 Saligny HV
Total = 25
ste - 1 Saligny HV
Luca72c - 3 Saligny HV @ 170Vac
Total = 25
Jazid - 2 Saligny HV @ 200VAC
IF POSSIBLE ALSO Jazid - 1 x Saligny LV @ 6-15VAC
ste - 1 Saligny HV
Total = 26
I have recieved these rectifiers. It is not clear how to connect.
The + connection is the only one indicated. Where is the - connection?
Jazid - 2 Saligny HV @ 200VAC + 1 x Saligny LV @ 6-15VAC
ste - 1 Saligny HV
Total = 25 Saligny HV + 1 Saligny LV
Luca72, yes you can edit the GB sheet.
I'm still experimenting with HV one. I'm thinking to push limits and make HV bridge operate up to 500KHz. This way will cover a broader range of applications and make it more cost effective.
Regards,
Tibi
I was very near to open a second GB for Saligny bridges.
I'm very proud of High Voltage and High Current products and I wanted to share them with this great community.
Unfortunately covid-19 pandemic is affecting entire planet, shipping is very slow making pcb purchase and many other parts very hard. All factories in Romania have been closed or keep running only essential subsections.
I'll not open this GB until things settle and I'm able to perform normal shipping.
In the mean time, you may show your interest and put your name on the list. No constraints to buy later.
I advice to all affected by this pandemic to stay home and use this time to finish long pending projects. Enjoy DIY and stay safe !
Best regards,
Tibi
Best regards,
Tibi
Good news Tibi, thank you.
Will you carry forward the names of those who previously registered an interest in the Saligny HV - I assume the list for the GB is the link in post 394?
You keep safe and well too.
