Ian asynchronous I2S and S/PDIF FIFO KIT group buy
Thanks qusp, I'll try to keep in mind .....the .... multi-channel FIFO.... 🙂.
Ian
you know, just in case you forgot…do want😎
pretty easy to forget with this going on, jeebus mate, this things going off!
have you prewarned paypal about the large influx? I would if I were you; sometimes they can be stupid and freeze your account...for your own safety 🙄 when large amounts of payments from different sources come in
1 JamesHill 1*I2S FIFO KIT 1*Dual XO Clock board 1*S/PDIF Interface Board
2 chansiukwing
3 lordvader 1*I2S FIFO KIT 1*Dual XO Clock board
4 karvid 1*I2S FIFO KIT 1*Dual XO Clock board
5 Blitz 1*I2S FIFO KIT 1*Dual XO Clock board S/PDIF Interface Board
6 daanve I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
7 Turbon I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
8 slartibartfasstI2S FIFO KIT -Dual XO Clock board
9 merlin2069er 1*I2S FIFO KIT 1*Dual XO Clock board
10 roger57 1*I2S FIFO KIT 1*Dual XO Clock board, confirmed right justified 16/24 support
11 andrea_mori 2 * I2S FIFO KIT - 1 * S/PDIF Interface Board-4 * 6" (need support left-justified format for SM5842)
12 ryanj 1*I2S FIFO KIT 1*Dual XO Clock board
13 Rupor54 I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
14 roenderI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
15 regalI2S FIFO KIT -Dual XO Clock board
16,17 PET-240I2S (FIFO KIT -Dual XO Clock board -S/PDIF Interface Board)*2
18 lwifI2S FIFO KIT -Dual XO Clock board - S/PDIF Interface Board
19 vd-twoI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
20 hochopeperI2S FIFO KIT -Dual XO Clock board
21 necplusultraI2S FIFO KIT -2* Dual XO Clock board
22 lllI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
23 NicMac I2S FIFO KIT - Dual XO Clock board - 2*S/PDIF Interface Board - 6*Universal XO adapters, 2*BIII u.fl and clock adapters - 4*4" double-ended 50 ohm coaxial cable - 4*6" double-ended 50 ohm coaxial cable
24 SPWONG I2S FIFO KIT -Dual XO Clock board
25 MisterRogers I2S FIFO KIT -Dual XO Clock board, 3 x universal XO adapters, 2x BIII u.fl and clock adapters, 3*4" double-ended 50 ohm coaxial cable, 3*6" double-ended 50 ohm coaxial cable.
26 Atom6422 1 x I2S FIFO KIT 1 x Dual XO Clock board 2 x 12” coaxial cable
27 hirez69 1*I2S FIFO KIT, 1*DUAL XO CLOCK BOARD, 1*S/PDIF Board, 3*BIII Adapter PCB INPUT (fully assembled), 3*BIII Clock Adapter (fully assembled), 15*XO Universal PCB Adapter, 8*4" double-ended 50 ohm coaxial cable, 6*6" double-ended 50 ohm coaxial cable, 4*12" double-ended 50 ohm coaxial cable
28,29 elecon FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
30 Rosendorfer : 1x I2S FIFO KIT - 1x Dual XO Clock board - 1x S/PDIF Interface Board - 1x I2S Backdoor - 1x BuffIII adapter - 3x u.Fl 4"" - 3x u.Fl 6'' - 3x u.FL SMD socket.
31 zinsula S/PDIF Interface Board
32 analog_sa1 x I2S FIFO KIT 1 x Dual XO Clock board 2 x universal XO adapters, 1x BIII u.fl and clock adapters 7 x 4” coaxial cable
33 tjencks 1 x I2S FIFO KIT 1 x Dual XO Clock board 3 x 4”
34 mravinsky 1 x I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
35 neb001 1x I2S FIFO KIT - Dual XO Clock board kit, 6 x universal XO adapters, 3x BIII u.fl and clock adapters
36 ccliu I2S FIFO KIT x1 Dual XO Clock board x1 S/PDIF Interface Board x1
37 florianderton I2S FIFO KIT, Dual XO Clock board, S/PDIF Interface Board
38 ENSen 1 x I2S FIFO KIT, 1 x Dual XO board, 5 x universal XO adapters, 3x BIII u.fl and clock adapters, 6*4" double-ended 50 ohm coaxial cable, 6*6" double-ended 50 ohm coaxial cable.
39 CeeVee 1 x I2S FIFO KIT, 1 x Dual XO board, 6 x universal XO adapters, 3x BIII u.fl and clock adapters, 6*4" double-ended 50 ohm coaxial cable, 6*6" double-ended 50 ohm coaxial cable.
40 kvl 1x I2S FIFO KIT ,1x Dual XO Clock board,1x S/PDIF Interface Board, 3x universal XO adapters, 2x BIII u.fl and clock adapters, 6x 4" double-ended 50 ohm coaxial cable, 2x 6" double-ended 50 ohm coaxial cable.
41 lindamar 2 x Universal SMT XO Adapters set , 3 x Additional BIII adapters PCB , 3 x SMT connector package for BIII adapters , 6 x 6*4" double-ended 50 ohm coaxial cable , 6 x 6" double-ended 50 ohm coaxial cable
42 bigpandahk 10 x SMT U.FL socket, 2 x I2S backdoor KIT for S/PDIF board, 2 x Package of Universal SMT XO Adapters KIT lot of 5, 4 x Additional BIII adapters PCB , 4 x SMT connector package for BIII adapters, (I've returned the FIFO to you for FW upgrade)
43 cracra 1 * I2S FIFO KIT , 1 * Dual XO Clock board ,1 * S/PDIF Interface Board, 4 * 4" double ended 50 Ohms cable, 4 * 6" double ended 50 Ohms cable, 6x universal SMT XO adapters, 3x BIII u.fl and clock adapters, 3 *SMT connector package for BIII adapters, 3 *Additional BIII adapters PCB, 2 * I2S backdoor KIT for S/PDIF
44 Eternalightwith - 1 * I2S FIFO KIT ; 1 * Dual XO Clock board ; 1 * S/PDIF Interface Board, 1 ; I2S backdoor KIT for S/PDIF
45 ruupie - 1 * I2S FIFO KIT ; 1 * Dual XO Clock board ; 1 * S/PDIF Interface Board, 1 ; I2S backdoor KIT for S/PDIF
46 BDL 10 x SMT U.FL socket, 1 x Package of Universal SMT XO Adapters lot of 5, 1 x Additional BIII adapters PCB, 1 x SMT connector package for BIII adapters.
2 chansiukwing
33 tjencks 1 x I2S FIFO KIT 1 x Dual XO Clock board 3 x 4”, 2x BIII u.fl and clock adapters, 2 *SMT connector package for BIII adapters, 2 *Additional BIII adapters PCB, 4*4" double-ended 50 ohm coaxial cable - 4*6" double-ended 50 ohm coaxial cable
2 chansiukwing
47 edlinssen:1*i2S Fifo Kit, 1*Dual XO Clock Board, 1*SPDIF Interface board,1*i2S Backdoor kit for SPDIF, 1* Connector package forBIII adaptors,4*4'' 50 ohms cables, 6* ufl fem. board connectors, 1*set of universal SMT XO adaptors.
Thanks qusp for your reminding, just sent email to them, hope there is no any problem.
Have a good night.
Ian
2 chansiukwing
48 asaf23 1*i2S Fifo Kit, 1*Dual XO Clock Board, 1*SPDIF Interface board,1*i2S Backdoor kit for SPDIF
2 chansiukwing
49 markus22ch 1*I2S FIFO KIT, 1*DUAL XO CLOCK BOARD, 1*S/PDIF Board, 3*BIII Adapter PCB INPUT (fully assembled), 3*BIII Clock Adapter (fully assembled), 4*XO Universal PCB Adapter, 4*4" double-ended 50 ohm coaxial cable, 4*6" double-ended 50 ohm coaxial cable, 2*12" double-ended 50 ohm coaxial cable
Ian, if I were you i'd stop the GB now, actually I would have a couple slots ago. you should allow for loss of a package just in case. then put the last 1-2 up for sale to the people last on the list when all arrive. good chance there will be no loss, but of a GB this size you should really prepare for it.
2 chansiukwing
34 mravinsky 1 x I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board - 1 x set of universal SMT XO adaptors - 1 x i2S Backdoor kit for SPDIF - 1 x SMT connector package for BIII adapters
2 chansiukwing
50 sernikus 1*I2S FIFO KIT,1*DUAL XO CLK Board,,1*SPDiF Board,3*SMT U.FL Socket,8*4"Coax Cable,1*I2S backdoor KIT,1*Package of universal SMT XO adapters,1* additional BIII adapters,1*SMTconn.pckg for BIII adapters
