Hi Ian, Hi everybody
I made a mistake 😱😱. Changing a battery on my LifePO4 mkII, i inverted the polarity of the battery in the BT6 position (i saw some sparks but nothing more).
Now when I turn on the system i have the correct voltage on J1 and J2 (i'm using the system with 4 battery but i'm using only J1 and J2)
BUT
when I turn off the system and it goes in "charging" mode, the BT6 doesn't charge the battery.
All other 3 batteries are charged properly.
the problem is that if battery BT6 is below the threshold, the system charges the other batteries continuously without interrupting (and therefore overcharges them).
If I remove the battery BT6 (to try to use the system only with the other 3 battery, BT7, BT5 and BT2) the voltage meter on the board measures around 2V, and so again try to overcharge the battery.
I suppose I burned something but I don't know what.
Can you suggest me something to control or to change on the board ?
There is another way to avoid using the BT6 battery ?
Thanks in advance
Paolo
BUT
Thanks in advance
Paolo
GB2023 interesting List
https://www.diyaudio.com/community/...-pdif-fifo-kit-group-buy.207438/#post-2919992
1. Iancanada SC-Pure 45/49*1, FifoPiQ7*1, UcPureMkIII*2, HdmiPiPro*1
2. casshan SC-Pure 45/49 * 1, HdmiPiPro * 1, UcBalancer KIT * 1
Thank you! Finally we are here!
3. princeliebe SC-PURE 45/49*1
3. Ben Mah SC-Pure 45/49*1, FifoPiQ7*1
4. WuBai SC-Pure 45/49*1, LinearPiMKIIDual*1, LinearPiMKIISolo*1
5. jiacheng SC-Pure 45/49*1, RFX OCXO*1, MonitorPiPro*1, UCbalancer KIT*2, PurePi*1, GPIO extender*2
4. Ben Mah SC-Pure 45/49*1, FifoPiQ7*1
5. WuBai SC-Pure 45/49*1, LinearPiMKIIDual*1, LinearPiMKIISolo*1
6. jiacheng SC-Pure 45/49*1, RFX OCXO*1, MonitorPiPro*1, UCbalancer KIT*2, PurePi*1, GPIO extender*2
7. pyflaw SC-Pure 45/49*1, TransportPi AES*1, FifoPi Q7*1, PurePi*1, UcConditioner 3.3V*1, MonitorPi*1
8. NewTheOne SC-Pure 45/49*1, FifoPiQ7*1, UcPureMkIII*2, HdmiPiPro*1, UCbalancer KIT*2, PurePi*1, StationPi Pro*1, ShieldPi Pro/MKII*1, RFX OCXO 45.1584 / 49.1520 MHz, Adapter KIT, SquarePi KIT, MonitorPi Pro
9. zapio: SC-Pure 45/49 * 2, TransportPi AES * 1, OPA861 I/V *1
10. WladimirMXP: SC-Pure 22/24*1, FifoPi Q7*1
11. Hires: SC-Pure 22/24*1, UcPureMkIII*1, MonitorPiPro*1
12. BasoFF: SC-Pure 45/49*1, FifoPiQ7*1, TransportPi AES*1, MonitorPi*1
SC-Pure 45/49*1, UcPureMkIII*2, UCbalancer KIT*4, PurePi*1, ShieldPi Pro/MKII*1, RFX OCXO 45.1584 / 49.1520 MHz, Adapter KIT, SquarePi KIT, SC-Pure 22/24*1
2019
13. smooth dancer: SC-pure 22/24, UCbalancer kit (1)
14.khh:SC-pure 22/24, UCbalancer kit (1)
15.triode4 SC-Pure 45/49*1, UcPureMkIII*2, UCbalancer KIT*4, PurePi*1, ShieldPi Pro/MKII*1, RFX OCXO 45.1584 / 49.1520 MHz, Adapter KIT, SquarePi KIT, SC-Pure 22/24*1
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
