So you edited both files and restarted, correct? When running Spotify, can you do "ps -ef|grep spot" and see if you get the full command line, maybe some parameters are passed there that force the bit rate or it is not using the spotout device. Also try to change hw:1 to plughw:1 in both files.
No change after I changed hw:1 to plughw:1 in both files.
Yep, there is the problem: --device plughw:1
it needs to be spotout
looks like volspotconnect2 doesn't have the logic to use spotout.
You can try and edit /data/plugins/music_service/volspotconnect2/index.js and change the line
toCode:var conf3 = conf2.replace("${outdev}", hwdev);
save and restart volumio.Code:var conf3 = conf2.replace("${outdev}", "spotout");
Nothing happened after I have done this change and restart.
Code:
var outdev = self.commandRouter.sharedVars.get('alsa.outputdevi$
var devicename = self.commandRouter.sharedVars.get('system.name$
var hwdev ='plughw:' + outdev;
if (outdev == "softvolume") {
hwdev = "softvolume"
var conf1 = data.replace("${shared}", shared);
var conf2 = conf1.replace("${devicename}", devicename);
Ah, they restore the plugin and wipe the changes, sorry, I don't know how to help you. Maybe go on the volumio forums.
ok, thanks!
Both of asoundrc and /etc/asound.conf are created by spotify configuration. When I do spotify configuration again, the contents of asoundrc and /etc/asound.conf will be changed to default setting.
You can check the index.js and see where it gets the templates for the asound files and edit the templates and Google where volumio stores the plug-in sources so you can edit those in order to get the changes you want to stick after reboots.
volumio-snapcast-plugin may solve this problem.
GitHub - Saiyato/volumio-snapcast-plugin: Volumio 2 SnapCast plugin, to easily manage SnapCast functionality
volumio-snapcast-plugin can not resample to 24bit. I give up....
Wow! I cannot believe that I finished reading the 4600+ posts of Ian's FIFO development thread! What a treasury. Though my head is still spinning, it is now clearer to me what kind of DAC I am going to build and how to walk the path. Thanks.
Ian, thanks for the great work! I have a few questions.
1) I suppose the MC FIFO also work for stereo. From your development thread, you mentioned that the MC_Dual_XO is even better than all versions of previous Dual_XOs. Now for MC_FIFO, is it at least as good as your previous stereo FIFO in stereo mode?
2) Since the MC-Dual-XO board only has u.FL connection for I2S, what is the largest resistance allowed in the I2S input termination resistors of my DAC board?
3) When will be the next group buy?
Thanks and happy new year!
W. YAN
W. YAN
W. YAN
Hi YAN,
Thank you those good words.
1. McFifo &McDualXo work for stereo applications for sure. You just need to leave the rest of channels un-connected.
Both McFifo and FifoII are doing good job to improve sound quality. But McFifo has built-in isolator and McDualXO has better LDOs. Even though,those LDOs can also be upgraded without limitation.(upgradable design).
2. u.fl coaxial cables have 50ohm impedance, so your end termination resistors should be equal or greater. But this configuration will lower the logic level. Since they are already source terminated, I would suggest the input resistors greater than 1K or just simply don't use any end termination resistor.
3. Next GB would be in March of 2018.
Happy Holiday and Happy New Year!
Ian
Ian,
Thanks. And glad to know that MC works great for stereo as well. I am into stereo but will try multichannel later on as well. So please put me in the interest list for McFifo and McDualXO.
March is a bit long...
Cheers.
W. YAN
Cheers.
W. YAN
Ian
A question about the power supplies. The manual states the following current draw:
MCFIFO:
avg: 160mA (more with higher freq. XO; plus other consumers powered by mcfifo)
min supply: 500mA
I am building a Salas Reflektor D's to power the MCFIFO board alone. The Reflektor's parts need to be matched to the load's current draw according to page 2 of the reflektor build guide.
Can I configure the Reflektor to be optimized to deliver 100-200mA with a max load of 400mA (R1=1.5 Ohm), or are 500mA necessary and the Reflektor should be configured for a constant draw of 200-350mA, 500mA max (R1=1.2 Ohm)? Or even higher (350-450mA current; 600mA max)?
Not sure what happens when I configure the Reflektor for too much current - it probably heats up more than necessary.
ElEsido
MCFIFO:
min supply: 500mA
ElEsido
Hi.
I have a problem with i2stopcmboard. The i2s led has turned off and does not turn on. It has worked correctly until today. Although with some problems with U-FL connectors. Review the welds and it has worked correctly a few days.
To be sure that U-FL connectors are not, I have disconnected all U-FL connectors and connected J3 (7 pin connector) and i2s light does not turn on either. The fifo and dualxo pcbs works correctly. Any ideas about the problem?
Hi.
Finally I think the problem is not i2stopcmboard. I have connected an i2s dac to dualxo output. This dac has worked correctly before with dualxo.
you hear it, but you can barely make out the music that is playing, it is a blurry and unpleasant sound. Does anyone know what is failing?
thank you very much
Ian
MCFIFO:
min supply: 500mA
ElEsido
100-200mA is OK I think.
Regards,
Ian
thank you very much
Did you feed mclk to that DAC? Please check the maximal mclk frequency of that DAC.
Regards,
Ian
Regards,
Ian
yes, mclk is connected, and the noise is with all the mclk frequencies.
Jorge
Best implementation for Sokoris DAC
Hi , thanks ian...incredible amount of work sir.
Iam a newbie as they say, however I have been moved to consider one of your products in conjunction with a Sokoris DAC?
Could you inform me as to the best way to I prove the Sokoris DAC in conjunction with what you produce? As the impression was the Sokoris DAC was fairly well sorted with its own clock regime? But I wanted to feed the 12sfrom a RAspberry PI running rune or mooed.
Sorry for the general nature of the question but I am trying to catch up and am looking for the best sound I can get whilst not being that technical ( what a quandary)....but we can do better for the money that the shop...or a less loss DAC.? 😕
Thank you
Johnny
Thank you
Johnny
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
