Ian asynchronous I2S and S/PDIF FIFO KIT group buy
New upgrading of FIFO board from V3.33 to V3.80
The upgrading job is finished. Please see http://www.diyaudio.com/forums/digi...imate-weapon-fight-jitter-46.html#post3015909 for details.
All of the upgraded features will be incluced in the GB II.
For GB I users, upgrading is free. Please just send it back to me in a bubbled envelope at any time if you want the new features. The postage will be much cheaper than in a box.I don't need cables and clock board. Just the FIFO board. I'll sent the upgrated board back to you in the same envelope.Both re-programming and loop testing will be required. I need confirm each bit is perfect for different formats before I send it back to you.
If you are happy with I2S and don’t required these new features, then you don’t need making any upgrading. Performance didn’t change any.
Hi Ian,
I sent you a message to cancel the order. I mistakenly thought it would work with TDA1543 but that seems very unlikely, and it seems I won't be able to get help here either.
My sincere apologies for this.
Tom
That's no any problem, Tom. Please come back to me at anytime you want. I'll try to keep some thing reserved after GB II. 🙂
Please go http://www.diyaudio.com/forums/digi...imate-weapon-fight-jitter-50.html#post3018812 to see my suggestions on your project.
I don't think there is any problem connceting FIFO with TDA1543. The only thing is your parallel configuration. For low jitter applications, you need figure out more to achieve better result.
Sorry for the late reply.
Regards,
Waiting list so far (May21,2012)
I summarized all the waiting list so far. Very close to 30. Hopefully I could start the second run production soon.
Please let me know if there is any thing I was missing. And for new registers, please just follow up this waiting list, which will make it easier to sum up.
1 JamesHill 1*I2S FIFO KIT 1*Dual XO Clock board
2 chansiukwing
3 lordvader 1*I2S FIFO KIT 1*Dual XO Clock board
4 karvid 1*I2S FIFO KIT 1*Dual XO Clock board
5 Blitz 1*I2S FIFO KIT 1*Dual XO Clock board
6 daanve I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
7 Turbon I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
8 KlipschKid 1*I2S FIFO KIT 1*Dual XO Clock board
9 merlin2069er 1*I2S FIFO KIT 1*Dual XO Clock board
10 roger57 1*I2S FIFO KIT 1*Dual XO Clock board
11 andrea_mori 1 * I2S FIFO KIT - 1 * S/PDIF Interface Board (need support left-justified format for SM5842)
12 ryanj 1*I2S FIFO KIT 1*Dual XO Clock board
13 Rupor54 I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
14 roenderI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
15 regalI2S FIFO KIT -Dual XO Clock board
16 PET-240I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
17 lwifI2S FIFO KIT -Dual XO Clock board
18 vd-twoI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
19 hochopeperI2S FIFO KIT -Dual XO Clock board
20 necplusultraI2S FIFO KIT -2* Dual XO Clock board
21 lllI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
22 NicMacI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
23 SPWONGI3S FIFO KIT -Dual XO Clock board
Ian
Updated waitlist
Just correct some mistakes, updated is listed below
2 chansiukwing
8 slartibartfasstI2S FIFO KIT -Dual XO Clock board
23 SPWONG I2S FIFO KIT -Dual XO Clock board
24 MisterRogers I2S FIFO KIT -Dual XO Clock board
Waitling list May 22, 2012
1 JamesHill 1*I2S FIFO KIT 1*Dual XO Clock board 1*S/PDIF Interface Board
2 chansiukwing
16,17 PET-240I2S (FIFO KIT -Dual XO Clock board -S/PDIF Interface Board)*2
18 lwifI2S FIFO KIT -Dual XO Clock board
19 vd-twoI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
20 hochopeperI2S FIFO KIT -Dual XO Clock board
21 necplusultraI2S FIFO KIT -2* Dual XO Clock board
22 lllI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
23 NicMacI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
24 SPWONG I2S FIFO KIT -Dual XO Clock board
25 MisterRogers I2S FIFO KIT -Dual XO Clock board
Ian
Hi Pepe
I'm happy you like the KIT.
Since I made the S/PDIF boards as same quantity as the FIFO boards, so I still have some in stock. Thay are ready for delivery. You can order it now.
Could you pleas calculate the total by yourself with an email sending to iancanada.mail@gmail.com ? You can make the payment after I confirm it.
Thank you and have a good day.
Hi Ian,
do you have still available the S/PDIF board ?. I totally forgot about this and never sent you my order by email.
Thank you,
Pepe
