Ian asynchronous I2S and S/PDIF FIFO KIT group buy
can I please add 6 x u.fl 100->120mm cables to ship with hochopepers order?
Ian can you add the above and 6 for me also.
So that would be total 12 x 4" u.fl cables and 4 x clock adapter boards for me (plus any if qusp wants more?) added to my order, qusp and I will split the costs up at our end so just send the amount to me.
No problem, I have enough cables. To save time, for the GB II, I will create a form which need you fill in and send back to me. So, just don't forget them when you fill in the form. 🙂
Ian
Waiting list update May29,2012
1 JamesHill 1*I2S FIFO KIT 1*Dual XO Clock board 1*S/PDIF Interface Board
2 chansiukwing
3 lordvader 1*I2S FIFO KIT 1*Dual XO Clock board
4 karvid 1*I2S FIFO KIT 1*Dual XO Clock board
5 Blitz 1*I2S FIFO KIT 1*Dual XO Clock board S/PDIF Interface Board
6 daanve I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
7 Turbon I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
8 slartibartfasstI2S FIFO KIT -Dual XO Clock board
9 merlin2069er 1*I2S FIFO KIT 1*Dual XO Clock board
10 roger57 1*I2S FIFO KIT 1*Dual XO Clock board
11 andrea_mori 1 * I2S FIFO KIT - 1 * S/PDIF Interface Board (need support left-justified format for SM5842)
12 ryanj 1*I2S FIFO KIT 1*Dual XO Clock board
13 Rupor54 I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
14 roenderI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
15 regalI2S FIFO KIT -Dual XO Clock board
16,17 PET-240I2S (FIFO KIT -Dual XO Clock board -S/PDIF Interface Board)*2
18 lwifI2S FIFO KIT -Dual XO Clock board
19 vd-twoI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
20 hochopeperI2S FIFO KIT -Dual XO Clock board
21 necplusultraI2S FIFO KIT -2* Dual XO Clock board
22 lllI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
23 NicMacI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
24 SPWONG I2S FIFO KIT -Dual XO Clock board
25 MisterRogers I2S FIFO KIT -Dual XO Clock board
26 Atom6422 1 x I2S FIFO KIT 1 x Dual XO Clock board 2 x 12” coaxial cable
27 hirez69 FIFO KIT, Dual XO Clock board, S/PDIF Interface Board,6 X SMT U.FL 4 X 6” and 2 X 4” double-ended U.FL cables (and 14 XO adapter PCBs)
28,29 elecon FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
It seems I could launch the GB II production next week.
Ian
2 chansiukwing
Ian
Please make mine the PMD100/right justified version- Thanks Regal
PCBs ordered today
Hi Ian,
I would like to purchase
1x I2S FIFO KIT
1x Dual XO Clock board
1x S/PDIF Interface Board
Rosendorfer
Hi Rosendorfer
You are the lucky guy who trigger the production.
PCBs ordered today. Each FIFO KIT of GB II will come with a set of new designed universial SMT XO adapter, again for free 🙂. Buffalo III adapter PCBs.... maybe 🙂.
I'll list order details once I get those PCB, hopefully next weekend.
Ian
i'll be interested in elecon's impressions, since it would seem to me that the fifo presents all of the advantages of the SDTRANS plus a couple of extras (particularly when speed setting is performed) so should equal or better sound quality, but with the convenience of being able to use computer as source instead of SD cards
Waiting list June 10,2012
2 chansiukwing
10 roger57 1*I2S FIFO KIT 1*Dual XO Clock board, confirmed right justified 16/24 support
30 Rosendorfer I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
31 zinsula S/PDIF Interface Board
The production will take two weeks after the PCB. I'll post the order details and arrange the payment before that.
Ian
2 chansiukwing
Ian
Hi Ian,
can I add 1 x I2S FIFO KIT and 4 x 6" coaxial cable?
So my order is the following:
- 2 * I2S FIFO KIT
- 4 * 6" double ended coaxial cable
Question:
can I feed directly PCM63 in NOS mode with I2S to PCM convertor daughter board?
Andrea
Hi Ian,
- 2 * I2S FIFO KIT
Question:
Andrea
Hi Andrea,
Yes, you can feed directly to PCM63 in NOS mode from I2S to PCM convertor daughter board. That's the design idea. But that daughter board will be after the GBII if I decide supply some.
Ian
1x I2S FIFO KIT - Dual XO Clock board kit
How many xo adapter pcb's will you have available? I'd like to buy 10 if possible 🙂
Count me in as interested in the Buffalo III adapter PCBs if/when they are available as well!
XO adapter KIT will be enough for this time.
If the BIII adapter PCB tested without problem, everybody will have one for free 🙂.
Ian
