Not sure if it would matter but I was hoping to crossover all three using Passive only, specifically lowest woofer handling 375-400hz and down then FF125 From that up to 10k then FT17 beyond that.
new front baffle could make it possible
not very difficult
your midrange should be at height with your face
if, and only if, crossing tweeter as a supertweeter, it wouldnt need to be closer to midrange
crossing woofer at or above above 300hz, it should be closer to midrange
so, all you may need is a new seperate baffle for the woofer only, rest is ok
mounting a new baffle onto the present would be very fine indeed
just cut a big round hole in the present, right behind the woofer
