Huge wow on diy turntable
Everything is dependent on everything else, I get it. The stretching of the belt however, had better not be a factor unless the tension of the belt is so high that it is indeed distorting the geometry of the belt. At that point, other issues would become more important, such as the added side force to the main bearing.
The fact that the wow 1-3% problem makes me believe that something is sort of friction sticking at some interval. Reminds me of something that might be out of round too. The spindle is the assumed center of the bearing, but upon viewing the stylus in play, is there a back-and-forth slow motion as the record is being played? I could see where a hard spot in the aluminum bearing could cause something to happen as well. Keen mechanical observation is needed.
@Trzalica you could insert a hard metal disc at the bottom of the spindle, so that it sits on the steel ball. The aluminium might have an indent that increases friction.
Steel ball is at the bottom of the bearing and the spindle has a flat (aluminum) bottom. I already asked my friend mechanic to reduce a diameter of bearing and spindle by adding a steel insert in bearing. He will polish both steel bearing and sintered brass spindle, as best as possible as well. I will also add a teflon insert at the bottom of a spindle so that there is no direct contact between steel ball and aluminum spindle.
... Diameter of the bearing shaft usually, for a platter about 5 Kg is 13 to 15mm, 30 mm is by far too big in my opinion. ....
I was just about making yet another BIG mistake by reducing a spindle to 9mm. After Adelmo recommendation i increase it to 14mm. Hopefully it is going to be good enough B)
HI,
About 20 years ago I made a DIY TT that is still working well, pic in my avatar. The platter is 4.6 Kg, on top of it I have a puc 500gr( just over 5 Kg the total weight ) and the diy bearing was made as follow:
Shaft 13mm made with hard steel and well polished
House made from solid bronze with tight allowance between bush and shaft. Bottom thrust plate from solid bronze too
Steel sphere 5mm
Oil lubrication
In 20 years I changed the bottom thrust plate once just because I wanted to change it but the bearing was still working well.
TT still running well, therefore my suggestion.
I would not use aluminum in any of the following part of the TT bearing:
Shaft
Bushes in contact with the shaft
Thrust plate in contact with sphere
Rgds
Adelmo
My experiences to date of learning about a cause of Wow, is that a eccentric rotation of the Platter Spindle can be a cause of a measured speed fluctuation.
A Standalone Strobe such as Keystrobe will easily show Speed Fluctuation, especially where the Kookiness of the Spindles rotation might be the cause.
I would check that before remachining the bearing. Is the circle where the o-ring is running on concentric with the bearing? Ask your friend that does machining to come round with a dial gauge and put it on the surface the o-ring is running. Turn the table by hand and see if the dial moves.
Hi Trzalica,
How well does the motor pulley fit the motor shaft?
Ralf
Hi Ralf,
This is a DARN good question, and probably right to the point. There is some wobbling when pulley (made not by my friend but by "professional machine shop" that I paid dearly) spins. I'll try to stabilize it by two set screws. If I can't I'll see if my friend can make a better fitting one.
THANKS, Trzi
Hello Trzi,
More set screws won't help. It is the degree of looseness between the pulley and the motor shaft that could be the problem. All that the set screw does, is that, it pulls the pulley off center to the motor shaft. The fit between the pulley and the motor shaft must be a slip-fit measured in increments of .0001".
You must measure the shaft diameter accurately with a quality micrometer caliper and give that dimension to the machinist. Dealing with a business is not a good idea, because there will be a supervisor who will be all over the machinist to "get her done". you might also include a tiny hole at the bottom of the pulley bore to "vent" the air when fitting the parts. Use a little grease when fitting the parts so they won't cease to each other when fitting. Last but not least, the bore in the pulley and the feature of the pulley that drives the belt, should be machined in the same set-up to ensure concentricity.
Sincerely,
Ralf
Thanks AGAIN Ralf,
I am not going to add more set screws B) I'll just try to tight them evenly (if possible) to reduce a wobble. Now I am taking a spare motor to friend so that he can make pulley as tight as possible. He will make a smaller (15mm) bearing with sintered (oiled) bronze in the base and spindle of polished SS as well.
With best,
Trzi
Probably too late to the party to be any help but I'm curious, What's the spindle detail inside the circle , and where does the platter sit?
