@ywh
Hi
I've ordered and paid for a 200w BSM-DC lamp via 18wheelers site. Can you confirm all is OK.
Hi
Hi all
Anyone heard from ywh lately? Just wondering about wether or not he received my lamp order.
Cheers
Cheers
Hi 121fred
my mail was generated by COREMAIL email system.
I have to wait message from 18wheeler
Hi ywh
Thank you for your reply and many thanks for this service. I have received confirmation of progress from 18wheeler. Looking forward to receiving lamp.
Does anyone know what the operating temperature of the lamp is? I can get a silicate based high temperature stove sealant that is rated to 500 degrees celsius and was wondering if this would be suitable to glue the replacement lamp into the reflector. I've used it before and it dries solid.
Cheers
Cheers
Hey YWH
I need a lamp for Plus U5 132 Projector
Details on lamp -
Ushio Japan
GK0077
NSH200PLB
thanks
Details on lamp -
Ushio Japan
GK0077
NSH200PLB
thanks
sharp xg-1000
hi im looking for a bulb for a sharp xg-1000 its 220 watts i tried to use a halogen 250 watt but no luck also i tried useing pro poxy 20 to hold bulb securely i think it will work any help on replacement bulb would be great thanks jo
thank you fred
thank thats exactly what i was looking for . now if i could figure out if its ac or dc . im guessing just take measurements of bulb voltage and ac or dc and insall is that all thanks again joe
Any details on the lamp or the projector? Also check manufacturers web site for lamp details then you should be able to work out a suitable replacement.
Cheers
Cheers
Hello ywh, I'm looking at the same problem. The lamp on my Benq PB6100 is fading fast. It's the USHIO NSH200BQ. Could you send it to Hamburg Germany? Cement and all?
Many Thanks, JayBobDee
Hi ywh
Alright so i got the 200w BSM DC lamp and I mounted as you described and this is what happened :
First time it turns on very less brightness and heats up a lot.
Second time i keep it in a very well air conditioned room..it doesn't heat but its still not too right.
Third time this is some sparking noise and the bulb broke.
Can you explain or do you know what went wrong?...also is 200w bsm dc the right lamp for infocus screenplay 4805 or should it be the 200w 'AC' instead ??...also please tell me which one should i order this time...i dont want to lose more money... i'm counting on you
vp6121
I have an HP vp6121 and the bulb is burnt out.... can someone tell me who it is I need to email to get a replacment without spending hundreds of $$$
Hi ankitgupta711 !
I rebuilt your lamp again, sent!
Hi jcurless !
your lamp is 250W UHP, I have no
Hi jcurless !
Its not my lamp...
Okay, so I found someone that had the same vp6121 projector and put my lamp in it... It worked great! So I took th projector apart and it looks like its the "color wheel" Can that be replaced?
Can anyone let me know where I can fin the instructions on how to install the bulb once I get it?
Thanks,
Thanks,
ywh said:Hi jcurless !
can you give me the picture of your color wheel? need a rule in the picture
I dont know what you mean by "a rule"..... sorry im new to this! But I can tell you my projector doesnt have a color wheel in it... I may be able to take a picture of the one like mine if that would help? the guy I bought it from thought the bulb went out and sent it to be "fixed" the place told him they couldnt get the part for it so he sold it to me for $30... So If i can get a wheel for it that will be great! if not maybe Ill just sell the good bulb and get my money back... 🙂
Can you give me an example picture of what your needing so I can get the right picture to you...
sometimes its the simple things that get over looked... Thanks for pointing out my oversite! I never would have connected that! guess my girlfriend is right when she calls me a dork all the time!
Ill try to take a few pictures (of mine and the one just like it) and we will see if we can get something done on this! thanks again for all your help!
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- HP VP6121 Replacement Bulb
