Horn/TL combo
I could be remembering wrong, but did GM suggest that horn loading of the woofer needs a big room. I am going to be sitting 10-12ft away.
For best overall performance, yes. At your distance you're still in the horn's near-field. Dual 15" and HF WG do better overall inside ~25-45 ft depending on horn flare/cut-off.
The Exemplar horns are more WG, so while a large room would still be ideal, they should sound more 'open' than an A7, etc..
Like I implied earlier, WGs are what's needed in most HIFI/HT apps, but the trade-off is they will tend to be large/deep and more expensive if a low XO point is used.
GM
Supposedly Tuesday is arrival time of 414's. I have 75ltr boxes that are currently sealed that I will port in an attempt to get an idea of sound in my room. I will measure all 4 and post results. Hopefully they are all close. Might have JBL LE15A back by then.
GM
Room is set up do that couch can be pushed back another 6-8ft, but if doing that, the room is starting to look like a barrel being 14' wide by 22'. Boxes seem to fit my room better than horn loaded woofers. Based soley on ignorance and others opinions combined with reading on the net
I wasn't saying looks had something to do with it, but speculating that in a long narrow room, continuing to back up further might not help because room reflections would come into play even more. The truth is, I could back up 25 feet from the speakers, but how many times would the sound waves bounce of the side walls, ceilings, and floors before getting to me.
whatever you do , you'll end with some big honker in big tall TL box , with horn on top
one 15" per box will make your life easier
if you were satisfied with your present liliputan spks , that will be certainly more than enough
anything bigger than that will overload the room , meaning exactly what you wrote - that you'll need to back up more , to ensure blending of all drivers
I was thinking that I could try dual 414's in individual boxes similar to what you calculated, conected side to side, ( maybe single large version). I could try the single 15 route with the JBL. It is not an altec but has very similar parameters, big VAS, low fs, low Qt.
we'll know more when you give us exact measured T/S , but I'm not expecting small boxes however ; what's dictating size is F3 and , combined with certainly not so low Vas ......
so - with 2 per side , it will go bigger than with one 15" , most probably , while I'm not expecting that solution significantly superior to one 15"
remind me ( yakyak , multitasking & multithreading , while I'm dumb ) where in thread are T/S for these JBLs ?
what I'm urging you all the time , is to go TQWT or MLTL ( whatever , I'm too dumb to differentiate them properly :clown: ) and leave plain BR for non-unitiated ones :rofl:
Again, speaker directivity [polar pattern] combined with proper toeing in and vertical height location limits these to a BW low enough to where they are down where our hearing acuity is falling off enough to not be an issue.
The closer you sit, the more you have to pull the speakers away from the side walls and the narrower the 'sweet spot' for a given speaker directivity.
Assuming you’ve chosen a ‘good enough’ directivity design for the speaker/LP ‘triangle’, worst case is you may need a nice thick area rug if you have a hard floor and maybe some decorative wall hangings near the speakers.
Whatever you do, don't have any reflective objects between the speakers and LP. I've auditioned/seen many otherwise properly done systems that were totally compromised by a coffee and/or end tables and/or a ‘lowboy’ front projector.
GM
buzz - not so bad results in same box I'm gonna use for my Tanns
NB that few details/dims are still missing on pic , but that's it in principle
