@ Egellings
After post by member V FETish 2SK180 is a special huge "Jumbo TO-3"
Hockey Puck SIT 2SK180 by Tokin source NOS
I am interested to know the packages names of THF-51S and 2SK182ES etc.
https://www.ebay.com/sch/watanabeto...Yl8AAOSwYjdgPc3t&rt=nc&_trksid=p2047675.l2562
I tryed to search but no luck.
Mytery industrial type maybe even uniq for those Tokin transistors only.
Very interesting.
I will continue my search then. 🙂
I find this transistor type beautiful. Especially shiny Tokins.
Can't stop staring on them.
@ RainfallSky
🙂 Toshiba make
This looong Toshiba case have a weird package name: Toshiba 2-32A1A
That must be internal Toshiba naming.
Sometimes when I search I see it named as TO-03A1
Also found datasheet for Fuji 2SD806
There is writen that it is EIAJ TC-19, TB-30
But if you open EIAJ ED-7500A catalog it's neither TC-19 nor TB-30 but a mix with pins like in SC-25.
Still searching.
Any recommendations where to get and what type of thermal pads for the THF51S? I have SITs on the way.
This is what I use:
CD-02-05-C-54 Wakefield-Vette | Mouser Canada
It does not have any holes so just punch to suit.
We would also need transistor washers.
Something 5-5.3mm wide and with 2.5mm height.
What everyone used in SissySIT?
@ RainfallSky
You can find thermal and transistors mounting kits from all big electronic components distributors: Conrad, Mouser etc.
My own was ready included with Tokin original accessories,
but if need finds something then local stores have lots of cheap solutions to offer
without being necessairy special fancy stuff for transistors.
Pras seller have bushing etc.kits for Tokin , contact him by PM on the forum
Sell thf-51s 2SK182ES NEW NOS to-79 SIT v-fet, from Japan TOKIN
1pcs NEW 182ES 2SK182 2SK182ES TOKIN V-FET(SIT) NOS japan Can be matched | eBay
Still searching.![]()
Interesting 🙂 Thanks
Toshiba produced as well Tokin 2SK180 Jumbo TO-3 equivalent with different package name G-TR
Wonderful to see all of this V-FET activity! Even though I'm new to amp building I'm not new to V-FET's. I still remember my first listen in the late 70's when I was a young warranty service tech for the local audio shop. To my ears the Yamaha and Sony V-FET amps sounded so much nicer than their BJT cousins and I was sure that V-FET's were going to be the next wave in the audio world. I had no idea back then that they were so expensive to produce and that they would quickly be replaced by cheaper MOSFET's and other cheaper technologies.
Here's a picture of my treasured piece of advertising that I've had it forever. Notice that there's an actual K77 and K75 wafer that were likely Yamaha fall outs that didn't meet spec.😀
@ V FETish & Diyers
Your first contact with Vfet amps was 50 years ago:^) Impressive!
What is Your mysterious brand amplifier with Tokin SIT's ? Maxonic ?
BTW Tokin case " Jumbo TO-3 " name by Toshiba are G-TR = Giant TO-3 transistor
🙂 Giant SIT's at the best price and quality NOS https://www.ebay.com/sch/watanabeto...Yl8AAOSwYjdgPc3t&rt=nc&_trksid=p2047675.l2562
The right insulating bushing reference for Tokin SIT is TW-10
Transistor Washer for PC Plastic Nylon Insulator Bushing TW10 TW9 TW6 TW3 | eBay
100pcs Practical Transistor Washer Insulated Plastic Spacer Bushing Washers | eBay
@ Diyers
You can buy from the same Ebay shop all mechanical elements for Tokin mounting kit
TW10: Transistor Washer for PC Plastic Nylon Insulator Bushing TW10 TW9 TW6 TW3 | eBay
Brass Welding Washers Terminal Welding Tin-Plated Gasket M2.2 2.7 3.2 4.2 - 8.2 | eBay
Flat Washers Solid Brass Gasket M2 M2.5 M3 M4 M5 6 M8 M10 M12 M14 M16 M18 M20 | eBay
Spring Washers A4 A2 Stainless Lock Washer M1.6 M2 M2.5 M3 M4 M5 M6 M8 M10-M30 | eBay
M4: 12.9 Cap Head Socket Screw Allen Key Bolts Screws Gold Metric M2 M2.5 M3 M4 M5 | eBay
https://www.ebay.com/str/glhk05?_bkw=nuts
- Hockey Puck SIT 2SK180 by Tokin source NOS
