Hello
So you say to use the connection at the mosfet version it was correct. Connect to the ground!? Like the schematic at the post 571?
Please advise if I understand it well. All do I want to go a bit higher PS voltage. About 17V rail voltage but I still do not think that extra 5V will do 5V swing.
Greetings Gabor
Yes, post 571 is correct for this input pair.
But just a tip that with higher power you also use a higher feedback divider (like Hiraga goes to 330 ohm/10 ohms in the 30 W version of Le Classe A).
The interesting part is that in this topology the output FET will have a different punch than in the F5 . . . and will definitely have a lower shoot-over. Good for e.g. electrostats or other complex drivers. (F5 exhibits overshoot at very high frequencies).
That explains my interest.
Thank you
Honestly I didn't heard big difference at the Class A with higher resistor on feedback or capacitor on feedback.
Actually I do not like capacitor on feedback on the feedback resistor very much. It get a bit muddy the sound..
If you exchange the 5 or 10W resistor for 0.33 that you can hear it right away. More dynamic, bass etc but the power transistors will get more load-- more heat.
To return to the LeMonstre I like these version. I want to test it.
I purchased the semis but one side they sent me not N type. Huge difference between the N type and with out.
I have to get the right mosfet. Also I prefer the red resistors from Parts Connexion.
I tried before Dale (not bad) Takman (not my cup of tea) but the PRP well balanced resistor (very little color or nothing).. I want to use that.
I never built the F5 but I built the Profet and not bad amp.
One think when we build a simple amp like these very sensitive to the parts what we use done to the wire to.
Thank you
Greetings Gabor
Thank you
Greetings Gabor
Hi all
This is my amp here, Fake +/- 21v
Amp board, so my question those two variable resistors, what do you think one is dc-offset ? and the other Bias ? but i don't know which one is which.
Hi all
Closer for input for DC ofset.
Regards zeoN_Rider
Thanks, i see that i have to adjust both. i presume about 0.5v will give 1amp bias. This is my first Hiraga amp, im used to Nelson Pass amps 🙂
Hi, everybody.
I want to do this project so I'm seach for "jean's hiraga 20w class A" on Google.
I found this pcb (see the picture) Do you think it work for this project?
circuit for this pcb
With best regards
Katip
With best regards
Katip
Katip, this looks like the version I have which has more capacitors whose function I do not know.
A while back i accidentally shorted something and it blew one of those diodes but that was good it blew the Diode instead of the Outputs.
I have this amplifier already built running from 12vdc step up to -/+ 24vDC ~
Probably going to sell soon as I prefer the F5 amplifier however I could try upgrading the Carbon film resistors to Metal Film before making a decision!
The Hiraga 20w is a very good sounding amp, just think it could be better! atleast my amp..
I blew a Zener on this amp some time ago, do we know what a good substitute is for one currently ? ill replace all 4. probably upgrade some of the parts, see if it matches F5 and then sell the amp as Ill probably still prefer the F5.
Ive heard BZX85 is a good substitute
Hiraga and F5
I have built both the Hiraga 20w and the F5 but I prefer the Hiraga without any hesitation (at least in my audio set-up). It is true that many versions of Hiraga super class A exist and the result could be different from one implementation to the other... Also I prefer the Hiraga with semi-lateral MOSFET output instead of BJT ( even with the very linear njw3201/njw1302)
Fab
Fab
what mosfet are those semi lateral? do you have the schema and did anybody tried or built the V-Fets (SIT)with sony 2SK60 and 2SJ18?I prefer the Hiraga with semi-lateral MOSFET output instead of BJT ( even with the very linear njw3201/njw1302)
Fab
2sk1530/2sj201
The schematic is the same but with different output trannies. It is a prototype and not ready for publication since this Hiraga design is sensible to used transistors and associated parameters. The parts values can change substantially and a study would be necessary to guaranty repeatable results for proper polarization of each stage....
Fab
Class A is overrated, built only as an experiment one channel of the Hirage 20 w, sounded good, but my goodness such heat generated.Is it worth the time and expense, NO. I compared it tp the much more simpler ESP PS3A R.Elliott amp,upgraded output transistors,using a good regulated power supply running at 45 v and a bias of 150 ma, well well, it sounded on a par with the class A if not better.Simpler and cheaper to build.
Each one to his own opinion.
Class A is overrated,...
That's not opinion. That's trolling.
"trolling" was not my intention i was only giving my opinion about a class of amplifier against another.That's not opinion. That's trolling.
Trolling is that what you mean?
The art of deliberately, cleverly, and secretly p....g people off, usually via the internet, using dialogue. Trolling does not mean just making rude remarks: Shouting swear words at someone doesn't count as trolling; it's just flaming, and isn't funny. Spam isn't trolling either; it p....s people off, but it's lame.
But how can you evaluate the sound imaging of an amp with only one channel😕.... Your comparison between these 2 amps is very questionable...except for the heat generation 🙄
Fab
Fab
I did say that the class A sound was good, but at the expense of an expensive and bulky power supply and generated heat. My opinion was that, compared to a simpler and well designed amp, like the PS3, it was not worth the expense.Anyway that's my opinion.
If one were to upgrade this amp what would parts be ? any suggestions ?
my resistors are normal carbons.
Hi Rixsta,
I'm also interested in this amplifier because now i have some suitable radiators from a old telecom equipment and two trafos at wich i am winding as we speak..
I think that the only upgrade is from the post 587 from this thread. I have found the same schematic from diy audio bulgaria, where a guy tries to put a 4 ohm load on this amp.
http://bgaudioclub.org/gallery/albums/userpics/11837/HiragaShemat_~0.jpg
I think that in this schematic we have to use the BL termination for the 2sa970.
This is the forum were i found the guys that actually tested the schematic and posted some impresions and the results. Can anyone help us with some ideas (translation) from the impressions of the guys froms the link from below?
????? ?? ? ???????? ?? ???? ????? ? ??????????? ?????????? ( ??????) - ???????? 11
- Hiraga 20W class A
