Hifonics BXI-6000D
The Fets marked in the Picture, but on the 1Ohm resistor close to the drive board i have the same signal. The disconnected cable is normally connected to the center leg of the right mosfet.
So, i have tried with fets inside, but than there is at this side no signal at all. If i connect the 9V batterie, there is no change, also the battery is not dropping.
I dont understand, how the 10v are generated. I have compared the values of the working side with the not working one, but there are no big differences.
According IRS Datasheet, VB(13) is connected with a capacitor to VS(11). VS is on the center pin of mosfet low side. 13 should over a diode connected to vcc.
