Ok, found some bad solder on the drive board pins for power supply. Now the amp is switching on, relay´s clicking, when you here the capacitors for audio charging the amp is switching of again. No Protect led or power is on. If i remove remote and put back, the same procedure again.
Got it work. Bad solder from my side. Because of this very often desoldering of that board, the solder points allready damaged.
Ok, Pictures: One side the working one as before, the other side with the new irs21844s without mosfets installed.
- General Interest
- Car Audio
- Hifonics BXI-6000D
