Hifonics Brutus BRZ1200.1D
Attached screen shot of pin 7 of the op amp that I shorted pins 6 and 7 together. Pin 5 connected to pin 1.
Yes, the noise sounds exactly like that.
DC voltages of IC6:
Pin 1) -13.73
Pin 2) -.026
Pin 3) -.027
Pin 4) -15.11
Pin 5) 0
Pin 6) -.001
Pin 7) -.001
Pin 8) 14.84
For the shorted op-amp, does pin 7 look the same as pin 5?
I don't know how the op-amp IC6 is being used. The fact that pins 2 and 3 are the same, seems to indicate that the op-amp is doing its job but the voltage on the output pin is odd, being so close to the supply voltage. From the numbers alone, I can't make any definitive conclusions.
If you short pins 1 and 2, does the voltage on pins 1/2 match the voltage on pin 3?
