Hifonics Brutus BRZ1200.1D
The first op amp (without a board designation, item #39) now has the following voltages:
Pin 1) .001
Pin 2) .001
Pin 3) .002
Pin 4) -15.11
Pin 5) .001
Pin 6) .0025
Pin 7) .002
Pin 8) 14.85
I get a distinctive hum when I put the positive lead from my DMM on pins 5 and 6 to check the voltage.
The op amp designated as IC6 now has the following voltages:
Pin 1) 14.45 (This voltage changed from a -13.73 to a positive voltage)
Pin 2) 1.206
Pin 3) .439
Pin 4) -15.11
Pin 5) .009
Pin 6) .011
Pin 7) .010
Pin 8) 14.85
I get a distinctive hum when I put the positive lead from my DMM on pins 5 and 6 to check the voltage on this one also.
I cut pin 1 on IC6 to remove it from the circuit. The 14.45vdc was still on the pin but not on the pad. I replaced it. In checking, I can not find any connections to pins 1, 2 or 3 on this chip. Pin 7 makes its way through a capacitor to R201 and to pin 8 of the output driver board. Pins 5 and 6 make their way back through caps and resistors to the sub-sonic potentiometer.
