Help me understand? 10kHz square wave thru my SE amp
Greetings friends. Having recently figured out how to hook up an oscilloscope+signal generator to an amplifier, I'd like to analyze my daily listener. So I put the sig gen in the 3k-65k range and put the scope on the 4-ohm resistor across the output terminals. Get a wave that looks like this:
As you can see, there's major rounding of that leading edge. What gives? Amp has no feedback so there's no phase lead cap to adjust. Here's the schematic:
Anything I should look at?
Thanks!
That is not so bad for 10K. No jingling at the edges. Maybe get a shot of a 1K square wave. Looking at that shot I would expect the amplifier to make it past 20K with a sine wave.
I fit is not the output transformer I would suspect you need lower impedance driving the power tube. You could reconfigure the 6sl7 for 6sn7 after changing plate and cathode values. Would have lower gain though.
Imho, your sig gen may have too slow a rise time, at something that looks like 50us, which is not going to adequately excite output transformer resonances out past 100kHz.
Another way to get a view of any ringing characteristics is to use no-load, or a capacitance load - if the amp is still stable (hopefully) then those loads may well show up high frequency damped ringing - which may be severe ringing but if they are damped (and not outright oscillation) then that is something you may be able to tweak feedback on to improve the stability margin. Not all output transformers generate an overshoot with damped ring with nominal load.
Reactions: kevinkr
Your square wave depicts a smooth frequency response roll off. This is an especially desired behaviors for stages relying on global feedback.
This roll-off can be either due to leakage inductance or shunt capacitance, but most manufacturers rely on shunt capacitance roll-off, as it is less dependent of the load nature. Leakage inductance roll-off output transformers can give very different frequency responses with changing speaker loads.
The smaller the rounding radius of the leading edge, the higher frequency response is (for the given frequency). Bit of a lumberjack explanation, but easy to understand.
In the end, your square wave is okay. Nothing to worry about.
It would be worrying if you got a shape resembling a sinewave instead of a 10kHz squarewave. :rofl:
Ya but what makes you think that? What makes the wave curve like that? Pretend I didn't study engineering. 😉
To produce a perfect square wave you need infinite frequency response. Any rounding of the leading edge of the square wave shows that you don't have infinite frequency response.
However, as others have said, the fact that it still resembles a square wave at 10kHz suggests that your frequency response is good past 20kHz and probably rolls off around 30kHz.
Some of our comrades can glance at a reproduced square wave and tell you all you need to know about the amplifier...
Cheers, Mike
Reactions: dubadub
That's quite good performance actually, I've designed and built dozens of SE amplifiers and until you get into very exotic output transformers 30 - 40kHz small signal bandwidth is about what you will see.
To get good square waves at 10kHz would require an output transformer flat to at least several hundred kHz with minimal (read no) phase shift and higher bandwidth circuitry.
That's a neat little oscilloscope. Do confirm that it can display undistorted 10kHz square waves.
Reactions: dubadub
