HEC amp
Can you produce us similar THDvPOWER (or/and THDvFREQ) graph for K200 as in post #96 ?
Two images, one at 10Khz and one at a more meaningful 2Khz.
Both for 4R and 8R.
Hans
The problem of stability was due to driver transistors spice model not compatible with Tina. I replaced them with MJE 15032/33 as well as BD139/140 the result is shown bellow. the distortion is 0.0043% that Tina measures and can be seen on the scope. So with the precedent drivers it can be between 0.0013 and 0.0043%. This is only with Rush. I will go back to the roots ,and try out the Hec only without outputs biased, to see if I can get similar result as with my reactor.
814592d1580950833-simple-power-bjt-mosfet-0-6db-output-hawksford-error-corrector-reaction-jpg
Hayk,
With all respect, but IMO you are turning LKA’s thread completely upside down with totally different designs.
Probably better to do this in another thread.
My contribution was just to show that the HEC concept is nice, but relatively complex to get optimal results compared to other EC schemes.
But compliments to LKA, he did a great job.
Hans
To mention a subjective experience from my side and based on just one single Class A amp was that when applying TPC, the already very low distortion started to become less as from 1Khz up to 20Khz but the perceived sound reproduction became cold and less involving.
Hans
