CLASS A Headphone Amplifier
Some material, convenient friends of the production.
Need to pay attention to, it USES AC 24-0 input, low voltage will make failure noise voltage.
Had better not exceed AC28-0.
10 the resistance controls the MOSFET IQ,
About 650 MV / 10 R = 65 MA
It is a, very hot. Headphone amplifiers
as sold in kit form on ebay for $30+$10 shipping
The mods should probably delete or move this thread, as it is not a diy project.
It is cheap though, I'll give you that.
This new PCB looks much better, than previous one.
Definitely.
The transformer should be 20W, and the dissipation/chanels mosfets (Q3&Q6, respectively Q8&Q11) is approx 3W/chanel.What transformer VA rating should I use for this kit?
How largr the Heatsink? Thanks.
AC24V voltage is more important
OR AC12-0-12 Series connection
shouldnt R16 R31 be removed ? it will form RC filter with headphone impedance -and you cant compensate for cable capacitance this way.
i also used line filter as no filtering device after 7824 ,next time use a low noise transistor please +1 irf610 wont be much of an expense
- Headphone Systems
- HA-PRO Single-ended MOSFET
