GZPA 1.4000 DXII
I have checked again. The heatsink is gzpa 1.4000dxii.. But on the board is written 1.4khc
Okay....HCX - it's the Hi Current board in the heatsink of the older GZPA 1.4000DXII.
What are the rail voltages in your amp ? b+ 14.4v of input ?
FDA59N25 - are only 250v but 59A so if yours is the hi-current model, this makes sense.
In all of the 1.4000dxii I've repaired the ones which are being used are FDA38N30 - 300v - 38A.
FDA24n40 - are only 23A but 400v - which are going to be a downgrade, not an upgrade.
However I've never seen amp with FDA59N25. Are You sure these are the originals ?
Keep in mind this are ratings ~ 25Celsius....and this almost never happens in an amp...more like 75-90 😀
So, ps is working, only 210v.. The fets then should work. I reassembled everything and under load, I have the upper half of the sine wave not good looking. What can cause this?
I will evaluate it later. Without load connected, everything is fine, i can go into clipping.
With load 1,2Ohm connected, and even small input it is allready disturbed. Also the rail voltage dropped very quick, and the oscilloscope cant recognize the voltage anymore.
That occurs allready with 12,5V DC and 7Amps input.
So here are some pictures. Hopefully it will help. 95v with gain at minimum. The other picture with gain at little higher. Input 10 amps.
The last picture is pulse from ps fet
Stays stable all the time.
I don't know.. If I connect the measure cables on common sec and rail plus, the output is strong distorted, without, it looks like the previous post, last picture. Anyway, if I go on the limit from my power supply, first it breaks down the positive half. Then the amp switch off with protection
Upper one is positive, lower negative. They are nearly the same. I made pictures at different input levels.
I have tested also before the audio input at the driveboard, with driverboard dismounted. The singnal is clean, which is going to the drive board.
So, it doesn't belong to my supply. What I found, is. If I look at the time base from the ps gate, it starts jumping, from left to right, double and so on. At the same time, when the distortion starts, the ps amplitude starts flickering.
I tested only a few caps, but the values are like new.
Its not a regulated ps. Do you have something in your tutorial about a feedback circuit for this? Also it seems, that there are small spikes, like noise all over the amplitude when it begins to flickering, but realy very small.
I have tried something to isolate the problem. I removed one side mosfets from audio, tested without these fets. Problem nearly gone. Installed the mosfets again, and removed the other side. Problem is back. So it comes from the one audio side. I think I I remove drive board and install new drivers.
