Gyrator Frequency Response?
To check at two different attenuation levels.
About right from what I measured on a bunch of different cables I had. Have a few AV cables that measure slightly better. Am reconfiguring my testbench to be able to employ very short leads to the soundcard and/or sound card interface depending on what I want to do.
Here you are, this is Emu Tracker Pre at 192kHz 65536pts FFT, no flattening compensation file, looping itself in pink noise at 1/12 Oct resolution. Green is crappy 1.5m coax they throw in $29 DVD players, looping alone. Did not make a change to 10cm RG179. Red is plus a pot set at midpoint, and thin 30cm aligator clips to connect it. Pot is corroded open metal case $2 100K Ohm carbon. 100K is the most usual value to be found in a tube preamp. Thus red is 50K Rs driving 1Meg input in essence. Miller of a tube or Cinput of card forms RC. For neutral measurements of this kind, buffering is essential. Else, passive components interact freely with the loop parameters, for nominal values and/or extra capacitances they may carry.
Even in DCB1 I spec 22K Log max because it limits BW (although far higher than here) and its a JFET buffer. Those high gm parts always have elevated Ciss & Crss. But the cable wasn't the problem in our example above. The high source resistance that the pot lend was. That is why buffered pots are better. Be it a DCB1 or my 6V6 bootstrapped cathode follower. Same story. Better than a pot alone.
Salas, In response to your post earlier regarding the noise of the zener. I did a little experiment before I switch out the zener with a couple of precision references. In the attached FFT plots, I compare the zener un-bypassed and bypassed. The cap used was a 220uF FC panasonic. 1V=0dB. I did not see a difference in this. I think I have a couple of precision references but haven't found them yet. Will post that when I do.
I am not sure what the hump is beteen 20k and 30k, but the unbypassed seem to perform better. The hump is part of the noise spectrum of the circuit. It is not present in the background FFT when I turn it off.
