Price for the input FET should not be a problem IMHO when you are planning on building a Goldmund clone...
New 2018 only by 2n556x metal case or 2SK240/2SK170.
Shared album - Chi?n Phan ??ng - Google Photos
https://photos.app.goo.gl/uiV6eHUtftWhqppf1
https://photos.app.goo.gl/tP9fsuDSDHa069Jh2
https://photos.app.goo.gl/0LKEraaoRQ6so0Il1
Thankyou for attaching the pics.
Using a remote server is a dis-service to our Members.
I'm sorry but I can't edit or delete.
I will note this case.
Thank u.
2SK170 are in separate houses, so even when matching them, you do not get the performance of the 2N556x as they share the same chip.Availability and price are an issue with the LSK389.
On my Goldmund LTSpice sim. THD is improved with the 2SK170, compared to the 2N5565.
But of course, to get that result the 170s have to be matched.
It would be nice to have the transductance of the 2SK170 inside a 2N556x though.
The input capacitance is the double in the 2SK170. You could try to simulate with two parallelled 2N556X and I guess you will get the same reduction in THD...!
Attacked for easy view.
The pcbs look very nice, but I always question if it's not better to use as thick
traces and even squares to fill up the space left after the components are placed.
Of course you need to separate clean grounds from dirty ones, and take them separately to the star. But I think thicker traces offer more advantages than a ground plane.
As stated in the above response I think the reduction in THD comes from the fact that 2SK170 has higher transduction and therefore higher open loop gain. You can get almost the same transduction from parallelling two 2n556x and then you also get the same input capacitance. So it is not the device itself per. se. that makes the difference.Of course perfect matched 2SK170 will improve the THD, because you used 2 identical JFETs for your simulation. In real life they are alltimes different. Maybe you' ll find 2 very similar ones, when you have tested 100 pcs. The main problem here is to find 100 genuine parts. Most of the offered one's on the internet are fakes, For a vry good matched pair (1%) , from $30 upwards you can count.
BR
Günni
PS: at Trensetter.com you can order in different case SOIC8 or TO-71/6
And then we are back to the point of the two 2SK170 not tracking each other as well as the two half parts in the 2N556X. IMHO it is one of the reasons the Goldmund sounds so good. The topology has been used, more or less exactly the same, in many other amplifiers, but with separate input fets.
Have you explored the dual U404 sold by Future Electronics?
Very nice price and very nice specs. It's also legit, no fakes problem.
Hi carlmart,
I used them (SST404 from Calogic) already in the AEM6000 designed by suzyj and i am very satisfied with them. And they also were available from the german distributor 😉
As the UPA68H the only problem is a little low forward transductance compared to 2N556x
7 compared to 12,5 typ.
I puchase a lot of these 2sk43, they are mached + -0.1mA.
The 2N556x is a two die put together in same case, which combines heat more closely. I will try to tie 2sk43. hope to achieve good.
The Sony 2SK97 (dual) very match to 2N556x, but they are hard to find now.
Why not DIP-8? DIP-6 is not able to plug in a NPD556X🙄
Hi Erikovsky, do you have PDF of the TO-3 PCB you have posted. I have a good stock of K176 and J56 to use with and happened to find 2 pcs 2n5566 for these.
I also have plenty of dual jfet of K194 and K58 and some K389 and uph68h as alternatives. also good quantity of k43. k44 etc.
I will start a Group-buy recently, the PCB will be gold-plated.
Eric
Will there be a version with to-220 power transistors?
Wait, what?!😀
Is there any To-220 package 10N/P20?!
- Goldmund Wiki and build 2017
