GB: SDTrans384 - A micro SD card digital transport
4 to 8 gb cards
Hi Sumotan,
Think you nailed it, i was thinking it was like my Squeezebox touch (64Gb SD card)...but treating it like a CD player with a smaller card is the best philosophy.
Thank you for that sir.....now to find those pesky class 4 cards!!
Best regards
Johnny
SDTrans connection to AYA DAC
Hi there all,All well i hope,, whilst waiting to find class 4 SD cards i now have in my procession a New AYA DAC and a new SDTrans 384 (firmware 3.16)
So what the best way to join them up in 12s mode?- I seen Sumotans picky, but its not to clear to me (wires crosses) and my PCB is differently laid out to his.
I have the BNC/SPDIF option fitted so when the input relays are energized it seen SPDIF (tested it , it works very well)- with relays (KR301/KR302)
de-energized, Ufl inputs J304/J305/J305/J307 are available for 12s input from the SDTrans.
On the AYA DAC Inputs available are:
j304= Data Left
J304= Data Right
J305= Bck
J307= LE/WS
On the SD TRANS when configured for 12s O/P the 8 pin header is labeled:
1= Lck 2=gnd 3 SDAT 4 Gnd 5=DCLK 6=Gan 7=MCLK 8=Gnd
I have an idea what to connect (but every one uses slightly different designations)...so can anyone be kind enough to advise me as exactly what to connect from the 8 pin header on the SDTrans to the AYA DAC inputs?
(I ask as i only want to connect the UFL once)
Thank you gents
Johnny
(I also have Ian Canada's PCM/12S PCB also, I assume that could be coaxed to work if Sim mode invoked on the AYA DAC??)...but first thing first eh!!
Just for you Johnny
There is a resistor that needs to be removed to get it working buy since
you mentioned that your Aya ds is different then pls check with Pedja.
Do note once you head this way you no longer can use the USB port ya.
Notsure if Pedja has made easier to retain the USB for your AyA
Cheers
Thank you Sumotan
Hi Again Sumotan,
Thanks for the reply, I am a bit confused by the photo showing the Molex connector CN8 connector-- its seems that LRCK/Ground seems to overlap to empty space? or is it me??
I think it would be:SD Trans CN8 LRCK to AYA LE/WS
CN8 SDAT to AYA DL/DATA IN
CN8 DCLK to AYA BCK IN
Cant try now (at work) but i think that would to it😀
Thanks to Sumotan for helping me!..ill read up about the resistor, but as i have no USB option fitted it may be OK as is in my case?
regards
John
I got the email too, and the price from Tachyon is:
SDTrans384(LCD color : Red text/Black back) JPY 49,800
Remote Control kit with Apple Remote JPY 9,800
Shipping cost by EMS JPY 2,800
I suppose the shipping cost will be location dependent.
I recently got an email from Tachyon that a new batch of SDTrans384 will soon be available? Anyone else get that and have gotten pricing for the run too?
TIA!
Greg in Mississippi
Hello Greg,
it's a good new. I discovered a few weeks ago the existence of this SD card reader by reading the very interesting discussions on this forum and TirnaHifi forum.
And I was just wondering how it was possible to order a card. Is it possible to have just the player or is there any new card with an associated dac?
Best regards,
Thierry
Good news indeed. I'll be selling mine here soon. I had it listed and the buyer backed out. I started listening again and got hooked all over and couldn't get rid of it. Like the siren. I'm going to box it up first this time so I can't change my mind😉 Realizing I just can't do the SD cards.
Hi Microzyma,
I'm interessed, what color is LCD screen on your SDTrans384 ?
Thanks,
Thierry
