Joined 2006
Sorry for getting back late Acid...was trying to find the manual. 😅
What you have is the sdtrans384 that's equipped with a daughter board, designed for i2C communication via hdmi to sync the 9018 sync dac.
I believe there are some pins on the board that needed to be enabled/disabled to toggle the config mode back for sdtrans384 to be used as a standalone i2s streamer.
I will continue to look for the manual (or perhaps I saw that description somewhere else). Will update should I be able to locate it.. in the meantime.. please look into this direction. Yamazaki san should be able to help you in details for sure, via sichoya <at> yahoo <dot> co.jp .
Best wishes on getting it working right soon. 😀
CFT, thank You. I already have the manual both or the SDTRANS384 and that daughterboard SDTRANS-SYNC-SDT. I resoldered the jumpers back as they should be for standard edition. I got it playing, just at the half speed. and what is missing just standard ROM, so I think that is why I got half speed play.
