I've seen pics rhing posted of your dugboards somewhere, I guess he must have received them🙂hui13
rhing
johnnygrace
korben69
ambiance
cmiu007
bdiermeier
Gooniman
Have you received your boards / kits?
OK, thanks...I want to clear my PM list for those that are complete.
Hello Dug, have you still the PCB to sell to me? Thanks.
I have boards and IC's...kits are done.
What would you like?
Yes, I received mine a while ago, sorry I forgot to post. They look great!hui13
rhing
johnnygrace
korben69
ambiance
cmiu007
bdiermeier
Gooniman
Hi Dug,
I did receive mine. I have not done anything to it yet-have been out of the country. Sorry for the late response.
Hi DUG,
I also received mine quite a while ago. Very nice, thank you. Project is also temporarily on the back burner.
Thanks people...I just wanted to clear out my pm list and move the transactions on my spreadsheet.
Sorry for not responding sooner. Been extremely busy with work and some tube amp projects. I received my boards with installed/tested ICs, and they look great. Thanks.
R7,C5...too many parts present.
If you are going to sync the two watch for master slave setup in gain resistor selection.
Other than that the soldering looks good...from what I could see.
Hi DUG
Thank you for your answers 😉
You mean soldered R7/C5 aren't required in my single board configuration ?
I'm not quite familiar with BTL as you can see.
My goal is a stereo set for 6.5 to 8 Ohms speakers.
Some guidance is appreciated 😎
Phil
Phil
Regarding C5/R7 I have had no feedback of any use of these on my boards.
However, there was someone in the TPA3116 thread that figured out values for the two when actually used...the values in the data sheet are wrong.
If they are to be used then the gain setting resistors need to be selected for master or slave operation.(see data sheet)
If they are not to be used then leave them off of the board and chose master for both amps. This what I am doing for my build...If there is a problem I will post it here.(and probably in TPA3116 thread)
Thank you DUG for your support.
I'll remove C5/R7 and choose master mode for both amps.
Phil
Phil
Are you powering both boards with the same power supply?
- Group Buys
- GB for TPA3116/8 PBTL bare pcb
