GB for TPA3116/8 PBTL bare pcb
Hi
A little update of my built.
Let me know if you notice something suspicious 😉
Phil
Hi DUG
Thank you for your answers 😉
You mean soldered R7/C5 aren't required in my single board configuration ?
I'm not quite familiar with BTL as you can see.
My goal is a stereo set for 6.5 to 8 Ohms speakers.
Some guidance is appreciated 😎
Phil
Regarding C5/R7 I have had no feedback of any use of these on my boards.
However, there was someone in the TPA3116 thread that figured out values for the two when actually used...the values in the data sheet are wrong.
If they are to be used then the gain setting resistors need to be selected for master or slave operation.(see data sheet)
If they are not to be used then leave them off of the board and chose master for both amps. This what I am doing for my build...If there is a problem I will post it here.(and probably in TPA3116 thread)
