Schematic, no problem.
On the other side of large:
http://www.diyaudio.com/forums/class-d/87913-class-d-amp-photo-gallery-91.html
Bottom post
Bottom post
DUG,
Do you have any boards and/or kits left?
I would like 2 x boards and 2 x kits, with the chips soldered please.
If I can have the two boards still attached (as a single board, it will be even better).
Johan
Johan
Cancel Request
DUG,
Please cancel my request for 2 x boards and 2 x kits.
After checking all my equipment, I realised that I don't have any speakers with a low enough impedance to get any benefit from the PBTL configuration of these boards.
DUG,
Hi Dug,
Is it possible to get two boards with IC soldered
$44CDN total + postage
the two boards still attached if possible.
I can take jagter5' ones 😉
PM sent.
PM sent.
Bottom post
Thanks 🙂
DUG,
OK
Thanks for letting me know right away.
Doug
Hi Dug,
PM sent.
LOL...pm replied
On the list.
Doug
DUG,
Do you have 2 more boards for me with chips soldered just like the 2 I have, they might be joined on 1 pcb, I don't care. I do have speakers for PBTL, I just need 2 PBTL boards per speaker I heard today and the DUG's drive hybrid electrostatics better then pbtl hiampmini's 😀
So I'm hoping to start putting my boards together pretty soon, although I still need to order most of the parts.
For the 3116, wondering if I should put some thermal paste on the thermal pad? First time I've soldered a SM part with a thermal pad like this.
Randy
Randy
Randy
I use a flux pen and apply to all the pads I am about to solder but especially where there are multiple, finely spaced pins.
There are some great tutorials around and I strongly recommend checking some out - sorry I can't find the one I found really helpful. This made the biggest difference for me.
You do need thin solder, I got 0.46mm diameter, flux pen as I mentioned, fine solder tip on your iron, fine tweezers and a good magnifying system, especially for these small chips. Oh also good quality solder wick - I used gootwick.
I have been doing quite a bit of SMD soldering over the years and never happy with the results especially on chips like the 3116. But this time I got it right, only made a couple of solder bridges which were easily wicked away.
Found the tutorial http://store.curiousinventor.com/guides/Surface_Mount_Soldering/101
http://store.curiousinventor.com/guides/Surface_Mount_Soldering/Tools/
3116 thermal pad isn't soldered to anything, I think???
Yep, you are right - I totally miss-read the post!
No, no thermal paste on the pad, the 3116 isn't themally connected like that. I think the thermal pad is for 3118 or 3110 maybe?
The 3116 part has a thermal pad on it, and the PWB has a corresponding thermal pad which looks like it wants to mate to it.
We use parts with thermal pads like this at work. It is intended to be installed with a hot air soldering machine and solder paste. But I have neither, so that's not going to happen. 🙂
Maybe I'm being anal, but I'll probably put a very thin amount of thermal goo on the board, can't hurt.
Randy
Randy
JohnLL
number9
bk856er
rhing
johnnygrace
zman01
birca1987
Your boards (and kits for some) have been mailed.
number9
bk856er
rhing
johnnygrace
zman01
birca1987
2 boards or a pair (joined)? Let me know I have both still.
With 2 IC's installed / tested.
I will put you on the list.
Doug
3116 thermal pad is on topside of chip, 3118&3110 have bottom pad. that is what I meant.
You're right. For some reason I thought the pad was on the bottom.
Nevermind 😱
2 seperate boards are easier, with 3116chips soldered please![]()
On the list.
JohnLL
number9
bk856er
rhing
johnnygrace
zman01
birca1987
Received today in good shape and nicely packed - thank you!
BK
- Group Buys
- GB for TPA3116/8 PBTL bare pcb
