Yes, i got 3 pieces of the psu and I liked it a lot, very strong bass and a lot of detail, is the same as my lt1083 linear psu, I think, never compared them.I see that you also got the Samsung OEM SMPS power supply, have you use it yet? How you like it? I think this is one of the best SMPS I seen so far and I have been using it to power my 3116 amp too.
http://h5.m.taobao.com/awp/core/detail.htm?spm=a230r.1.14.1.2drZgT&id=15993309912&ns=1#detailCan we get a link to this Samsung OEM SMPS power supply.
ÕæÆ· ÈýÐÇÔ×° 24V5AµçÔ´°å 24V5A¿ª¹ØµçÔ´ 24V5A ÒôÏ칦·ÅµçÔ´-ÌÔ±¦Íø
And thank you for letting me know the boards have arrived...I am waiting for 11 other people to let me know. 🙂
Doug
Sorry I don't believe that I confirmed receipt... I did receive my (4) boards a few weeks ago.
Thanks Doug!
Sorry, DUG, I forgot to let you know that I received mine a while ago as well. Just haven't had any time to start working with them. Maybe this weekend...
Thanks guys, just trying to keep track.
Alfi
ambiance
irribeo
Pascal GUERIN
Your boards/kits/amps have been mailed.
Alfi
ambiance
irribeo
Pascal GUERIN
korben69
cjkpkg
Your packages have been mailed.
Got them...beautiful boards! Try to get them stuffed by the weekend.
Any good recommendations on some type of thermal "glue" to adhere a heatsink to the chip? I have some sinks but they would not utilize mounting holes.
Some people have used this stuff:
J-B Weld | Original Cold Weld Formula Steel Reinforced Epoxy
I haven't for heat sinks but it really is a great product and I would use it if I needed to use it for heat sinks.
Doug
Doug
Tools needed to remove tpa3116 heatsink
I'm far from an expert, but the FAQ for J-B Weld says it's not electrically conductive. Not sure what that means for thermal conductivity, but for adhering a heatsink to an IC, you want something that is very thermally conductive (to get the heat away from the IC and to the sink as quickly as possible).
I recently bought some of this: Arctic Alumina Thermal Adhesive. I am familiar with this company from working with their product that is designed to mate CPUs to heatsinks ("Arctic Silver"). The latter compound is not a permanent adhesive, though, as CPU heatsinks have mechanical mounting mechanisms. The "Alumina" product I linked is a true adhesive, however, it's both a 2-part epoxy-type product and thermal compound.
There are other thermal adhesive compounds of course, that's just the one I've happened to use. I used it to glue a heatsink to the TPA3116 IC on a Ybdz "Wiener" board.
I have used the $1 tube stuff on Ebay, it certainly fastens the sink well with a very thin layer of adhesive. No idea of the heat conductivity as the 3116 puts out very little heat.
For the DUG board I glued the sink to an aluminium bar that was drilled and bolted to the board/chip - easily removed.
Hi Dug,
I've received my board yesterday found it today (sunday!) in my mailbox Pretty fast considering that the post date was october 15th.
Thanks Dug 🙂
The boards are about the same size than my Sure TPA3116 boards.
I must look at the BOM now ...
Thanks Dug 🙂
I'm interested in a DIY board like this but stereo BTL, I have no need for PBTL because I will be driving 8 ohm speakers.
Is there any chance that you will make a stereo BTL spinoff?
DUG I did receive the boards. This is my first group buy but common sense should have told me to look in here and acknowledge. Anyway to this newbie they seem professionally done. Thanks Johnll
First: most people are using these for an 8R speaker alone...the options for most of the parts are its' features.
I have four stereo BTL boards coming next week...one is spoken for...a kit for that one is also requested.
Doug
Not a problem...somewhere in this thread are the BOM and board views of where the parts are located.
Doug
- Group Buys
- GB for TPA3116/8 PBTL bare pcb
