to be fair and keep it real
The ‘cram’ models in ‘para’ seem to address some of the time domain or (whatever happens) issues after talking with Matthew .??? The Iong skinny resonator replacing the short wide is likely the solution as I found immediately in my ‘experiments’ with parallel qw pipes?
cheap 48hz fun to test anything(scaled down to 4” x 2 or 4. Then you can present yourself an example of all these things before investing in the fancy expensive stuff
on the below design that was for the 12tbx100 originally, i plugged in the skar 12ddx
however it gave me a 10db difference from at the XO point, so i lowered the Lpt from 75 to 10 and that made the response more even
what i did in HR i do not if can be done on the real life
see the plan below
BEFORE AFTER
see the plan below
BEFORE AFTER
Btw, i plugged the skar in the SS15 and gave me one of the ugliest batman shape responses i have seen 🙁
moving the sliders don't get rid of the wings or decrease the valley in the middle just moved the overall freq response or the stuff up high above 100
looks like TH designs hate car drivers
