How does mass damp? I see that phrase used often, but it has never made sense to me.
se
Inertia.
Like when common sense runs into a gibberish wall.
It's forward momentum is halted.
What I should have said was:
Mass Addition will reduce the effect (system response) of a constant excitation force.
Are we happy little campers now🙂
Mass addition lowers the resonant frequency, where it's more difficult to damp. I'd go with light and stiff. Higher resonant frequency, much easier to damp.
se
Stiff stuff resonates. For damping, you want a relatively pliable and flexible material. And heavy too, so that it moves little under the application of force.
Lead or brass cymbals?
Less energy stored in a lighter structure... does make sense.
I look at it more as a function of frequency. Think acoustics. What's it take to absorb 20Hz vs say, 1kHz?
se
Everything resonates. Less stiff will just resonate at a lower frequency. Not as easy to damp.
se
se
Easy to deverify. Take a thin piece of triplex and a similar sized piece of mdf, tap both, listen.
Perhaps more audible when the resonance is at a higher frequency.
The assumption is that it will be damped.
se
Listen for what exactly?
se
LampizatOr The Lite 7 DSD DAC | AudioStream
Nearly $6000 and they won't tell you the DAC they use, because it doesn't matter.
The designer answered that of course different veneers affected the sound, because colour is transdimensional
Of coure, because Energy = Mass x Colour Squared....
I just stumbled upon these Magic Tubes crap:
Mad Scientist Audio :: Magic Tubes
I can think of an application that he hasn't thought about yet, it requires sticking them. Also, he could stick more of them, for added effect.
Yes, far more effective than just mass which only store energy just to release it slowly.
Even when using a 80 kg TT it's amazing what a light yet stiff TT support can do.
Cheers, 😉
se
Cheers, 😉
I've been using solid core everywhere for decades. It does make an audible difference and it has its advantages practically speaking when you're building P2P.
Cheers, 😉
Sorry for the late reply - but solid core can make a big difference in video. Like make or break. Audio? That's another story.
Cheers, 😉
And they're so reasonably priced! 😱
Mike
- Member Areas
- The Lounge
- Funniest snake oil theories
