Here is the circuit I used. I also stuffed the enclosures with Polyfill.
You may find R3 having too much bottom, but you can increase the value to remove that.
Did any body made changes for Lii Silver10 ?
I'm planning to EQ it in an open baffle use.
Should I omit P1 if I'm following Nelson's "starting point" circuit (bass reflex use)?
I don't think there's a BOM because many parts have to be calculated with microcap following your in situ measurements (see Nelsons article in post 1).I’m a little late to the party.. I just ordered mine. Did I miss the up to date BOM or should cobble a parts list?
After replacing the resistors with correct values I have the Full Range EQ working now, it sounds really awesome, I’m getting a bit of buzz in the background that the EQ seems to to introducing ie it’s no longer there when I remove it. Any suggestions as to what it could be?
I’ve populated the board according to the example in the Nelson Pass article. Im using a Meanwell power supply and running it between my laptop and an Amp camp amp mini amplifier, speakers are fostex full range speakers.
- Full Range EQ
