I use Alpair 10.3. No need for EQ with that one
But some like to suppress the ringinf up high.
dave
I highly recommend the SEAS FA22RCZ.Put phase plugs in and they do not really need any EQ.
dave
Dave, if I find a strong enough adhesive to reattach the magnet that fell off, I'll be in touch for some phase plugs. 🙂
Nix that idea I suppose. I suppose I'd better take this conversation to a different thread/forum so as not to clutter Mr. Pass' thread.Put phase plugs in and they do not really need any EQ.
dave
The magnet itself isn't broken. It just separated from the basket because the mounting rivets weren't compressed properly into the basket and the glue holding it failed.Broken magnet. I had a pair where one got a bent basket before it even got used.
dave
If I need only high frequency boost a little bit for my Ribbon Tweeter by cut off low/mid frequency lower 3KHz, how can I change or remove any parts ?
Thread's gone a little quiet so time for a couple of questions!. Firstly I assume that the values of C5 and C6 are 10uF and 1000uF? Secondly the pdf says that the high or low filter sections can be disabled, how is that achieved? Further to this would it be possible to switch the high filter on or off on the hoof somehow?
I’m also interested on a workable loudness button circuit for ACA mini amp. My app is near field bookshelf using my klipschAny thoughts on using this as a loudness button as it roughly approximates Fletcher–Munson?
Just had a demo of a pair of Cube Audio Jazzon and Nenuphar - pretty similar level of performance to be honest, with the Nenuphar having an smidge more polish, detail and soundstage - but I would happily go for the F10 select given the cost/benefit ratio.
The F10 Select driver holds a lot of promise, detailed, dynamic, it does bass and has great width/height to the soundstage. But it was (for me) shouty and lacked soundstage depth because it was so forward in the vocal region. This was the same with two different amplifiers a 300b and an Enleum/Bakoon.
If the FR was equalised, and the presence region pushed back into the mix, then would this add depth to the soundstage as well as taming it shouty nature?
It’s a very tempting solution, but I still wonder if EQ is enough to ‘do the trick’ of righting the wrongs of a full range driver of if so should just stick with point source, but using multiple drivers…
It's really frustrating to have things sell out so quickly. Sold out after five days? Really?
Is there going to be another run?
Well I added in two of the boards with my iron pre shipment. Just sort of happened to coincide.
Pretty sure nelson&Jason just underesttimated our demand (is this the correct term? Sounds demanding to me)
Mine arrived a few days ago, all the way to 'Oz' - neat board, plenty of room for changes, mounting holes, etc - excellent. Many thanks to Nelson for doing this rather useful little project plus supplying the measured 'transistors' with the resistors
Could someone please explain what C6 does in the circuit and whether it makes sense to use a more expensive film cap. Thanks!
- Full Range EQ
