Folsom EC7293: PVI Powered Frontend, 60/120w 8/4ohm
Turns out it was bad soldering between the PVI cells and the board
I re-soldered one channel after tinning the cell and it worked !
Unfortunately I pulled the pad off one of the cells on the other board 🙁
So I ordered a couple more, now I have to wait...
Just finished my EC7293 and have it playing music !!
Measurements were good on start up 😀
35.5 VDC power input
8>02 VDC on the PVI and both channels less than 0.5MV offset
Reactions: asuslover
Hi , I'm late to the GB, I've checked all around for the 7293v chips and none are available ... does anyone have any of the 7293v Chips ???
- I need 4 , right now it looks like the earliest possibility is October or November..... Seems so far away --- thanks for any help .
Digi-key lead time estimate for the TDA7293V
Ship dates are approximate and subject to change.
Quantity Expected -4
Ship Date Estimate 6/7/2021
So how does it sound pinocchio?
Here's the Google English translated URL. I don't know how faithful of a translation it will be, but it will give you a good idea!
Google Translate
Do
Did you get to listen to this build using your reference speakers? How does it compare to other amps you've built?
(ps For context pinocchio built my EC7293 last year but I didn't ask to put in speaker protection circuits because destroyer_OS didn't feel they were needed. This meant pinocchio didn't feel safe listening to the build through his reference speakers.)
