FirstWatt J2
@ernesternest,
from the first pair SS looks the trace as vor using them, the second pair is inside the J2..
@Dennis Hui,
yes I changed also the power supply to another one and shorten the input pins. After minutes or hours the crackling / breezing comes and goes (sound like a fire). Yesterday was a day without any issues.
ZM,
thanks for you thought.
I use my "standard" pads => BER178-ND
Every time I used new ones and cleaned the heat sinks and the SS.
Today the J2 plays normally, next time I will try Al-Oxyd-pads. It is for me an (expensive) try and error game with the SS. :-(
do you have thermometer, contact type (temp. sensor is NTC, little metal blob) ?
Replacing Caps
I just got a used J2 and noticed it has a couple of bulging caps. I'd like to replace them with identical replacements but I can't tell what brand they are, anyone know? They're 25V 15000uF.
Also where can I find info for setting the bias on this particular amp?
Sounds gorgeous BTW
Thanks ZM. Looks like mine are Pana M's which I can't find but Mouser has these CDEs available SLP153M025C4P
It buzzes for one second as it powers up is that normal?
I'm not sure if I should replace them or just ride it out. Am I risking any other components if one of those caps spontaneously combusts?
It's old enough to be using the 8-cap board (assuming there was a method to the madness) and dual jfets (2SJ109BL). I think another member showed a picture of their J2 which had 109BL on one side and J74 on the other channel.
Your caps might actually be 25mm but if you're going to replace one, may as well replace them all as long as you can desolder the old caps properly. Sure looks dusty in there!
Is there a date code printed on the top of the caps?
The bulge is just the shrinking plastic making the top plastic disk warp. Usually it means that the amp has been run in a warm environment or poorly ventilated. If you pop the plastic top you will see that the aluminum can is still flat. Routinely the caps are good, so not a reason for sleepless nights.
Ok, just chillen over here. On the left channel the output measures about 25mV. The resistors are .709V
On the other left channel the output is about 28mV and the resistors .705V
so, you're perfectly good
now enjoy
btw. that pic doesn't count - no Porn, no Glory
btw. - it's funny how you have two left channels, and none right
Pa is so clever!!
how I didn't came with idea to make an amp with two same channels .......... :clown:
