First Watt F7 review
Not sure why it would be sad...seller has a good rating and they are in the US.
If you are just getting a couple of pairs, it's fine.
If you are buying in bulk, just buy direct from Profusion.
10 pair of same lot number laterals (to PA, USA) came to $130 with expedited shipping.
As per papa everything is on the table except it is official. Can you please look below images and let us know your thoughts. One is original diagram f7 manual and one from internet and one is actual amp. Look How it is so beautiful with no caps and very less resistors(with pots) components and only 4 transistors.
Thanks.
Yeah It is complicated but first stage is correct as per the document "The beast with thousand JFETS". And second stage is correct as per F7 manual, Both are provide by none other than Papa. So if we combine both the circuits we can expect working F7 circuit. Once I got 2SJ74 & 2SK170 I will build and test I verified exicon lateral mosfets they are identical to F7 laterals .
Ejam,
Actually I don't have background in electronics. very Little knowledge. Here we are feeding out put to input stage. As per my understanding it is not negative feedback, so we can assume positive feedback. someone have amplifier/audio circuits experience please explain 1095 post,
Thanks.
