Finally, I've tried S&B TX102 TVC with a GC amp
Evolution.
As you see Peter, ultra minimalist may not always be the way to go.
I'm very happy with the sound of my pre (OPA627+BUF634) working with my GC power amp (LM3875).
It's the best combination I've tried so far, and the first one I made.😀
And I tried several chips and implementations.
Some people reported very good results with an op-amp as a buffer, or even a valve.
I tried op-amp as a buffer and liked the results.
You now tried transformers and say it's very good.
This is evolution.😀
Deam it, your boxes are s'beautiful.:bawling:
Come around, I need help with the boxes.😛
Hello, I would like try transformers within passive "preamp", but the one mentioned here are out of the league (pricewise). I have found in my junk bin two mini transformers made by Tamura ( MIT-17). I think, those are impedance matching ones. Primary is 15kOhms, secondary is 600Ohms with CT. The only problem is their bandwith: 300Hz - 100kHz. Can those transformers be used in passive "preamp"?
Remember they'll have a loss of 5x. You might be able to improve the bottom end by driving them with a low source impedance. If you have them try them anyway, as their spec might be for full power, and at lower levels they have a better response.
A more basic issue is they have to be made to be a TVC. A transformer for a TVC should have maybe 20 or more taps. Each tap ends up going to a switch. Selecting a different tap gives you a different volume. Since you talk about CT, it does not sound like the right kind of transformer.
BTW, I think TVC transformers are expensive because they are probably a lot of work, making all those taps.
Companies that make the right transformers, that I know of are S&B, sold through Bent audio over here, Audio Consulting, sold through referenceaudiomods and sowther (sp?), who does not have a US distributor that I know of.
I once saw a review when someone compared different TVC's, I will see if I can figure out where I saw it.
Randy
They're definitely not TVC's.
JCoffey said:
Is it just a step att. connected to all the different leads of the transformers?
No. The transformer has a number of different windings and taps that are then connected to a switch. The turns ratio of the taps means that when different taps are selected via the switch there's a known amount of attenuation.
The schematics Randy linked to should make it clear.
JCoffey said:
Thats pretty much what I figured after looking at the schematics. But,where you you get the switch? Does it come with the transformers or is there a special one that I'd need?
The switches usually sell seperately, but I beleive Bent offers some packages with them included. If rolling your own, any 24way 2 pole quality switch will do; Elma, Seiden, Shallco etc
Bent sells the Seiden switches, which look really nice, but are not cheap. I was going kind of low budget, and used electroswitches. If I every redo my preamp all out, I would probably use the Seidens.
I actually used a 3 pole switch, and used the middle switch as a shield, with grounded copper tape all around the middle switch. The Seidens are shielded already, so you don't need the DIY shield if you use those.
Randy
Peter Daniel said:
Of course the current version has still some rough edges...
I addressed most of the weak spots of previous design and here how the improved preamp looks. This is by no means a commercial version, but something I built yesterday for myself.😉
Three layers of acrylic are used here and no more gold plated hardware, but polished brass: looks much better this way. I also added 0.5" to the width and this improved final appearance.
Lets see the back!
Wow btw, that looks AMAZING!!! I like the addition of the 2 layers of acrylic, kind of completes the look 🙂
Send one my way 😛
Or you can take a trip to here in the summer (nobody wants to come here in winter for a good reason).
That's too much. I have to say that it looks better than 99.9% of any diy projects, or any commercial products. Actually, I can't think of something that really looks this good. A work of art I say!.
So your wife is tolerant of all this? Where do I find one of these? (j/k my gf is actually VERY tolerant of my hobbies, so long as 100% of the money and time doesn't go towards them - i.e. so long as i don't ignore her .. she even attentively listens to me ramble on about diy for a long while before starting to get a little bored! a real keeper!)
